Did a full LED swap on my 2011 Cayenne
Old Oct 2, 2011 | 10:22 AM
EasternLI's Avatar
EasternLI is infamous around these parts
I'll stop in tomorrow and ask, havent driven at night in a couple days, ill check it tonight and see how they feel
Old Oct 4, 2011 | 07:01 PM
turbostang's Avatar
turbostang has a spectacular aura aboutturbostang has a spectacular aura about
Ordered 12 wedge led bulbs and 2 festoon led bulbs today from ijdmtoys.com
http://store.ijdmtoy.com/SMD-LED-Doo..._t10_sku11.htm
http://store.ijdmtoy.com/SMD-LED-Map..._d42_sku23.htm
I want to swap out the puddle lamps and the sunvisors to led, unfortunately I cant figure out how to take it apart.
Old Jan 5, 2015 | 06:42 AM
f30er's Avatar
f30er is infamous around these parts
Anyone figure out how to open up the side mirror puddle lights??
Old Jan 5, 2015 | 03:21 PM
mmdht2's Avatar
mmdht2 is infamous around these partsmmdht2 is infamous around these parts
you have to disassemble the whole mirror housing. I chickened out at the first step "pry out the mirror".
Old Jan 5, 2015 | 08:01 PM
TGED's Avatar
TGED is infamous around these parts
I did my mirror puddle lights
Old Jan 5, 2015 | 08:03 PM
TGED's Avatar
Another pic.
Old Jan 6, 2015 | 03:23 AM
f30er's Avatar
Exactly the pic I needed! How did you pry off the housing? Or did you take off the mirror first?
Old Jan 6, 2015 | 05:20 AM
TGED's Avatar
You need to pull off the mirror first, it helps if you adjust the mirror so the outer edge hangs out and you can pry it out. Next is to remove the body color housing, you need to release some clips from inside of the housing, but you need to remove the mirror motor in order to get to the clips. Because the bulb is horizontal, you want to get a LED with bulbs on the side otherwise it won't be bright enough, also the LED cannot be too long or it won't fit the bulb housing. Hope this helps.
Old Jan 6, 2015 | 05:37 PM
Matt911's Avatar
Matt911 is infamous around these parts
This instruction is for the Touareg. It has the same side mirrors as the cayenne.
Originally Posted by MBX5
Just give it a good tug and it will pop out
2 screws and two tabs inside towards the top release this part
Once you get this part off you must remove more screws and then take the top (silver) part off then the lower black part.
Credits to MBX5
Old Feb 5, 2015 | 06:19 AM
Vyper340's Avatar
Vyper340 has a spectacular aura aboutVyper340 has a spectacular aura aboutVyper340 has a spectacular aura about
I have the LED upgrade in my CTT but noticed the footwell lights are not LED. I pulled the one under the driver but could not open the "case" the light was in and didn't want to force/break it. Anyone have advice on how they got it open/replaced?
How are the rear seat footwell lights??
Old Feb 5, 2015 | 07:10 AM
mmdht2's Avatar
the red part clips into the clear part. you just pop it out. just have to press the right spot.
Old Feb 5, 2015 | 07:49 AM
Vyper340's Avatar
The footwell is a box like plastic piece that pops out and unplugs. I could not separate the box and lens to access the bulb...
Old Feb 5, 2015 | 07:17 PM
TGED's Avatar
I remember for the footwell light I had to pry hard around the outter casing. I managed to changed all four of them to LED.
Old Feb 6, 2015 | 03:01 PM
carlosC4S's Avatar
carlosC4S is infamous around these parts
Can anyone list the bulb types for the full interior so I can upgrade my 2010 958 CTT when I get it on Monday please?
My 2011 CD has the comfort light pack which has many of these lights in LED already so I want the Turbo to be white light too?
Carl
Old Feb 8, 2015 | 08:28 PM
mmdht2's Avatar
Carl
they are all t10's except one festoon in the luggage compartment.
