Did a full LED swap on my 2011 Cayenne
Old Feb 18, 2015 | 07:58 AM
  #31
mmdht2's Avatar
mmdht2 is infamous around these partsmmdht2 is infamous around these parts
It pops right out
Originally Posted by Vyper340
I have the LED upgrade in my CTT but noticed the footwell lights are not LED. I pulled the one under the driver but could not open the "case" the light was in and didn't want to force/break it. Anyone have advice on how they got it open/replaced?
How are the rear seat footwell lights??
Old Feb 18, 2015 | 08:11 AM
  #32
carlosC4S's Avatar
carlosC4S is infamous around these parts
Can you help with the lights above the rear doors for back seat passengers?
Old Feb 18, 2015 | 08:42 AM
  #33
mmdht2's Avatar
I think they just pop out as well. it's attached firmly I remember. I will check tonight when I get home.
Old Feb 19, 2015 | 06:51 AM
  #34
mmdht2's Avatar
there is a small torx screw inside you have to remove then you can pop the whole thing out.
Old Feb 19, 2015 | 01:58 PM
  #35
carlosC4S's Avatar
Brilliant thank you, what about the horse shoe light in the front?
Old Feb 19, 2015 | 02:58 PM
  #36
mmdht2's Avatar
that you can just pull right out. very easy.
Old Mar 1, 2015 | 12:52 PM
  #37
Vyper340's Avatar
Vyper340 has a spectacular aura aboutVyper340 has a spectacular aura aboutVyper340 has a spectacular aura about
Originally Posted by mmdht2
It pops right out
That's not the footwell lights. I believe those are the door lights.
Old Mar 1, 2015 | 01:44 PM
  #38
mmdht2's Avatar
foot well lights:
even easier, just reach behind it and push it out. it's clipped in on one side only and the other side slides in.
Old Aug 2, 2015 | 07:13 AM
  #39
Airbus Driver's Avatar
Airbus Driver is infamous around these parts
Does anyone knows or already upgraded the mirror puddle light to led ?
Old Aug 2, 2015 | 08:32 AM
  #40
wexford911's Avatar
wexford911 is infamous around these parts
mmdht2 any chance can you take a picture and show where to pull the horse shoe light?
Thank you!
"SORTED"
Old Aug 2, 2015 | 11:38 PM
  #41
TGED's Avatar
TGED is infamous around these parts
You need to pry away the mirror glass, remove the mirror base, remove the body color cover, then you can pull out the light socket.
Old Aug 3, 2015 | 01:02 AM
  #42
MIK911's Avatar
MIK911 is infamous around these partsMIK911 is infamous around these parts
Thank you!
Ditto. Would like some Intel on how to change the horseshoe light to LED. Read another post stating it is very difficult to access the horseshoe bulbs
Old Aug 6, 2015 | 08:58 AM
  #43
Originally Posted by TGED
You need to pull off the mirror first, it helps if you adjust the mirror so the outer edge hangs out and you can pry it out. Next is to remove the body color housing, you need to release some clips from inside of the housing, but you need to remove the mirror motor in order to get to the clips. Because the bulb is horizontal, you want to get a LED with bulbs on the side otherwise it won't be bright enough, also the LED cannot be too long or it won't fit the bulb housing. Hope this helps.
Hi TGED, what exactly led bulb did you use ? Thanks !
Old Aug 6, 2015 | 02:33 PM
  #44
TGED's Avatar
Sorry, I don't have a photo of the bulb I used, you need to find a shorter LED bulb, it can be slightly longer than the original incandescent but not by much as the space is very limited. You also need to find a bulb with LEDs on the side of the bulb because it goes in sideways, if you install a bulb with LEDs pointing at the end it won't be bright enough.
Old Aug 6, 2015 | 11:03 PM
  #45
AZN_C300's Avatar
AZN_C300 is infamous around these parts
I've got these in mine. Works great:
http://www.aznoptics.com/index.php?m...products_id=95
