Window Tint for Cayenne
Old Apr 22, 2012 | 08:32 AM
dimok's Avatar
dimok is infamous around these parts
I want to tint windows on my Cayenne in a way that front windows would match rears. I am considering Huper Optic vs Llumar airblue ceramic tints that, according to what I researched, are high end films that will dissipate the heat. I would be interested to find out what kind of tints fellow forum members installed and how does it look (pics).
Also, any advice on a quality shop in tri-state (NY, NJ, CT) area would be appreciated!
Old Apr 22, 2012 | 07:12 PM
vitaman's Avatar
vitaman is infamous around these parts
Had Huper Optic on my last car. It looked good and was at least somewhat effective against the heat. Main problem was that the tint shop stuck to the legal limit on the front windows so they were always lighter than the rest of the car. That had something to do with diminished heat reflection and of course a diminished look!
Old Apr 22, 2012 | 08:15 PM
trovan's Avatar
trovan is just really nicetrovan is just really nicetrovan is just really nicetrovan is just really nice
I think the heat issue will not be that different between films. But most important is to find a film that will match. I asked the shop to cut small pieces of different films and stuck on the window to see how they match. Most 20% will be darker than the back. I prefer them to be the same but definitely avoid front darker than back. Some films will have different color or reflection from OEM in the back. I ended up with a lumar film at 35%. Good luck.
Old Apr 23, 2012 | 12:22 AM
V10M's Avatar
V10M is infamous around these parts
Does the 35% Lumar match the factory rears? And is it a little lighter or same shade?
Old Apr 23, 2012 | 10:53 AM
steph280's Avatar
steph280 has a spectacular aura aboutsteph280 has a spectacular aura about
Heat blockage is very different between different films. Many shops have this rig where different films is placed under a red heat lamp. With ceramic type of films you almost feel no heat, even when the film is very lightly tinted. On the other hand, a cheaper dye film will allow heat to pass through even if it's 5% limo tint.
I think the factory tint has around 40% light transmission, but then again that differs between different brand of films. I like Trovan's idea of having them put on test pieces of films. I just went 20% all the way around because I wanted the privacy.
My shop used these "Winco" films which has a slight blue hue when viewed from inside, but completely black from the outside. It has some of the higheset IR blockage ratings (96% or something).
Old Apr 24, 2012 | 02:56 PM
dimok's Avatar
Trovan,
Could you please post a pic of your car? What type of Llumar film did you use? I spoke to one high end tint shop and the owner told me that if I want to do ceramic, then in order for me to match the rears, I will have to have 2 layers of film in the front and 1 in the back. I don't want to do that. Then he told me that I will have to put Llumar standard film (Non ceramic, I don't know the type) on the fronts to match the rears. Does your front matches the rear?
Old Apr 24, 2012 | 03:20 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
check a previous thread of mine where I talked about the tint, gave you specifics on the 5 I went through and then my final decision based on 100% identical all around.
I cant find the link, but search.
Main this that will matter is if you have insulated glass, that makes a normal tint that would match, NOT match.
good luck.
Old Apr 24, 2012 | 04:38 PM
dimok's Avatar
good luck.
Jace, that looks great!
Do you have insulated glass? I don't. Do you remember what brand and % did you get?
Old Apr 24, 2012 | 04:48 PM
ferraristyle's Avatar
ferraristyle has a spectacular aura aboutferraristyle has a spectacular aura about
I used f1 tint 20 % and looks like factory
Old Apr 27, 2012 | 07:52 PM
dimok's Avatar
ferraristyle, where did u do your tint? What brand of film did they use?
Old Apr 28, 2012 | 09:26 AM
Jace's Avatar
I have insulated glass which makes it hard to match perfectly bc of the purplish color.
I went 18% on front and 28% on rear.
AWWS or something like that was the brand.
Lifetime warranty non metallic. Original owners of suntek started their own company this one.
Same great quality.
Without insulated, most brands work perfectly with look from inside out and outside in.
Old May 9, 2012 | 01:01 AM
Premier Films's Avatar
Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !Premier Films Is a GOD !
This is what we use
- 98.5% of IR blockage even at just 65% vlt (visible light transmission)
http://www.prestige-films.com/auto_photosync.shtml
Here's our own test:
https://www.6speedonline.com/forums/...ml#post3539003
Premier Protective Films
ClearGuard Alpha PPF, Spectra PhotoSync Nano IR & CeraLuxe IRD Tint, Coatings
www.premiermobilegroup.com
Sharing our Passion on Youtube: https://urlgeni.us/youtube/Premier
Facebook: https://urlgeni.us/facebook/Premier
42630 Christy St, Fremont, CA. 510-623-1308 sales@premiermobilegroup.com
dgreen78
Feb 29, 2016 11:28 PM
ModBargains
991 Turbo Vendor Classifieds
Oct 13, 2015 03:56 PM
ModBargains
GT3/GT2/GT Vendor Classifieds
Oct 13, 2015 03:55 PM
