Oil change simplification
Old Jun 1, 2012 | 11:09 PM
spartacusmcfly's Avatar
spartacusmcfly is infamous around these parts
Has anyone installed a Fumoto drain valve on their Cayenne? If so, what size fits on the Cayenne without hitting the plastic under-engine cover?
I've had them on all my Benz's for the past 5 years and they work beautifully. Allows me to complete my oil change in less time than 15 minutes.
SB
Old Jun 4, 2014 | 06:45 AM
grohgreg's Avatar
grohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of light
I installed the F106N on my Cayenne Diesel, but it's a bit tricky to get the threads started due to the proximity of the drain hole and that silver underbody cross-member. A 90 degree adapter would fix that issue, if I could find one. Right now the Fumoto has to be installed vertically, hence the tight fit and messy draining (cross member and under-body panel catch oil). A 90 degree adapter would turn it into a horizontal drain AND extend the valve beyond both the cross member and front under-body panel.
//greg//
alwaysbored786
Apr 19, 2016 05:51 AM
4ocious
Sep 1, 2015 06:44 AM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
