Cayenne Diesel MPG. Post yours:
Old Mar 14, 2013 | 11:51 AM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Originally Posted by cfgtts
Also, I have been adding up the mpg manually. I have found my PCM is always over generous by 1.5mpg.
Yeap I do the same. And found the same.
Old Mar 14, 2013 | 06:54 PM
powdercoatmike's Avatar
powdercoatmike has a spectacular aura aboutpowdercoatmike has a spectacular aura about
averaging about 25 on the PCM., so 23.5? Still twice what the expedition got.
Got 20 towing my racecar to the track, again double.
Old Mar 15, 2013 | 09:34 AM
Booch's Avatar
Booch is a jewel in the roughBooch is a jewel in the roughBooch is a jewel in the roughBooch is a jewel in the rough
My best to date was 31mpg (hand calculated), which was all highway driving from Baltimore to Providence, via an overnight stop in Brooklyn. The next trip averaged 68mph and 29mpg, although it was partially in the mountains. City driving I get low 20s.
Old Mar 15, 2013 | 11:26 AM
binner's Avatar
binner is infamous around these parts
These numbers are very impressive ... can't wait for arrival.
Old Mar 15, 2013 | 06:22 PM
grohgreg's Avatar
grohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of light
I think the discrepancy between hand calculations and the car computer has to do with the built-in speedometer error. Corporate bean counters and lawyers cause the speedos to read ~3 mph slower than indicated. It's a liability thing. I got this number by comparing the speedo to a GPS app on my iPhone. So I'm doing an measured 57 when the speedo says 60, which translates into a 5% error. Subtracting 5% from my indicated 36.2 means my best so far has actually only been 34.4 mpg
//greg//
Old Mar 16, 2013 | 12:42 AM
RedBent's Avatar
RedBent is infamous around these parts
Some impressive numbers here. Since it looks like entry and drive will be available for MY '14, I really hope my wife will enjoy test driving one of these!
Old Mar 16, 2013 | 02:39 PM
porschevin's Avatar
porschevin is infamous around these parts
Is there a way to display overall MPG rather than for just that trip in PCM?
Old Mar 16, 2013 | 03:54 PM
gnat's Avatar
I got 12 today!! Happened to be while auto crossing, but that's worth something right
I'm guessing 12 is just the bottom of the scale because the distance to empty and my overall kept dropping significantly.
Old May 7, 2014 | 04:28 PM
lab racer's Avatar
lab racer is infamous around these parts
Mpg
My speedometer shows indicated speed of 73, Garmin GPS speed 70. This is a 4% error. Overestimating the distance traveled by 4%. To get truly accurate mileage we should subtract 4% of the miles from the odometer reading in order to calculate an accurate mileage. Even when we calculate the mileage we over overestimating the MPG by 4%.
If the computer overestimates by 5% that would mean the computer overestimates by 9% over actual.
Something to think about.
Old May 7, 2014 | 04:29 PM
lab racer's Avatar
Mods
Any mods to help MPG?
on a Subaru STi, a 2 inch lip on the front air dam increases highway mileage by 2mpg.
Are there any front air dam's available for the CD, maybe something in the Porsche family?
Old May 7, 2014 | 06:55 PM
hoovdini's Avatar
hoovdini is infamous around these parts
Speed and distance traveled are two different things though - just because the car thinks you got there faster does not mean that the distance is further. In other words, the speed and distance are not tied...unless I'm missing something here.
Old May 7, 2014 | 09:16 PM
lab racer's Avatar
let me see:
MPH is distance per hour
If the speed is higher per a given time it means more distance was traveled.
The only except would be if there was a separate cable, ie mechanical measurement for the odometer.
Old May 7, 2014 | 09:56 PM
hoovdini's Avatar
let me see:
True, however total distance traveled is not linked to speed. If you drove 90mph instead, that doesn't increase the trip's total miles.
Your odometer is correct, it's the speedo that's off.
Old May 7, 2014 | 11:26 PM
gnat's Avatar
This is an old thing and there is lots of information out there about it. Speedos can have a lot of slop in them and will even vary between cars built on the same day. I've seen speedos up to 10% off.
And no the mfg is not likely to do anything about it unless it under reports. It's the laws about it under reporting that have them err on the over reporting side.
Your ODO on the other hand has some strict regulations about how accurate it has to be and a "bad" one will only be off by a mile or two every 5-10k. If you find that your ODO is under or over reporting, you get that documented and addressed ASAP.
audipwr1
Sep 25, 2021 01:31 PM
socialpro
Cayenne 958
Sep 16, 2015 10:00 AM
Qu4ttro
Cayenne 958
11
Sep 4, 2015 01:35 PM
Drk Knight
Cayenne 955/957
Aug 28, 2015 03:08 PM
