Regarding LED light.
Old Oct 22, 2013 | 07:39 PM
  #31
TGED's Avatar
TGED is infamous around these parts
The Panamera uses the festoon type of license plate light which is different from the Cayenne. Because of the open back design of the housing, there is no problem of over heating from the resistors. In order to avoid the error code, the LED bulb must also consume the same 5 watts of power, since LEDs consume very little power, most of the power is consumed by the resistors and the energy gets dissipated as heat.
Old Oct 23, 2013 | 10:55 PM
  #32
gelkad's Avatar
gelkad is infamous around these partsgelkad is infamous around these parts
Lic plate led
Just installed on my 2011 cayenne turbo ECS tuning LED lic plate light, no error code ( ES# 2093774), took 10 mins to install
Old Oct 24, 2013 | 05:20 AM
  #33
TGED's Avatar
But you need to operate the new LED lights for a while to see if the resistors over heat.
Old Oct 24, 2013 | 08:12 PM
  #34
gelkad's Avatar
for the past three days , no over heat, seems to be operating fine
Old Oct 24, 2013 | 08:29 PM
  #35
TGED's Avatar
You need more time to tell. Mine didn't start to 'brown out' until a few weeks after. And it also depends how much nighttime driving is involved. Please report back later. And if everything is ok, I will buy the same ones you have.
Old Oct 24, 2013 | 08:40 PM
  #36
gelkad's Avatar
3 hrs on I-94 for 3 days in a row, I will let you know in 2-3 weeks time
  #37
TGED's Avatar
I just checked the ECS TUNING LED license plate lights, they actually mount the resistors in a separate module away from the LED bulbs to avoid the over heating problem. But this is not a clean install when compare to a plug-and-play LED bulb module with built-in resistors.
Old Oct 24, 2013 | 08:44 PM
  #38
gelkad's Avatar
They are separate yes but still they are in line and its a clean install
Old Oct 24, 2013 | 08:47 PM
  #39
TGED's Avatar
Where do you mount the resistor modules? I see the kit comes with some plastic cable ties.
Old Oct 24, 2013 | 08:49 PM
  #40
gelkad's Avatar
There is enough space on both sides behind the light assembly
Old Oct 24, 2013 | 08:53 PM
  #41
TGED's Avatar
Thanks for the quick reply. Please report back in a few weeks and if all is well I will go with your way.
Old Oct 24, 2013 | 08:55 PM
  #42
gelkad's Avatar
I will Bro, It looks 100% better , I hope it will work fine
Old Oct 25, 2013 | 03:12 PM
  #43
kechang's Avatar
kechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to behold
how's the color on those ECS?
is it pure white like the OEM kind? Noticed a lot of aftermarket LED tends to be too bluish for my taste
Old Oct 25, 2013 | 05:18 PM
  #44
xray doc's Avatar
xray doc is infamous around these parts
I've had success with 5000k LED color temperature. It is as about true white as you can get. Anything above that temp you get a bluish hue. Seems to work well in the cayenne. Although the rear footwell light's wire is too short for me to swap out on my own.
Old Oct 25, 2013 | 05:30 PM
  #45
xray doc's Avatar
For license plate LED mods, I will also say the resistor modules seperated from the bulb housing is a better bet. The heat generated from the resistor mechanism will not come into contact with the the clear plastic housing that could potentially discolor.
