side view mirror distorted!
Old Jan 17, 2013 | 04:59 PM
stronbl's Avatar
stronbl has a spectacular aura aboutstronbl has a spectacular aura about
My 2013 Cayenne diesel with auto dimming mirrors do not have the distortion in the drivers mirror, so it may have been a bad manufacture batch as noted above. As long as the service folks notice and agree with you, they should be willing to replace the mirror under warranty as the distortion could be a safety issue in some driving conditions, at least that is what I'd claim and have them note it on the service form.
Old Jan 17, 2013 | 05:18 PM
RAKLAW's Avatar
RAKLAW has a spectacular aura aboutRAKLAW has a spectacular aura about
I will try also but I have done some much hi way driving both day and night I would have thought I would have noticed.
Upon second thought objects stay in the mirrors for such a short time, I may never get the chance to test
Old Jan 17, 2013 | 06:43 PM
Harlequin NY's Avatar
Harlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of light
I just tried the same test sitting in my Durango and no waviness. It has a 9" wide mirror.
Old Jan 31, 2013 | 05:27 PM
ghb's Avatar
ghb
ghb is infamous around these parts
Removing stock side mirror on 958 Cayenne
Originally Posted by wwilliams88
I like the Euro mirror. I removed the standard one as soon as my Cayenne was delivered and pop in the Euro style. The image is smaller since it is aspheric, but it eliminates the blind spot issues without the need for a stick on convex mirror. LCA helps, but it is not a cure all for the visibility issues.
Here some more discussion in the 997 forum if you are interested. I also have these on my Carrera.
https://www.6speedonline.com/forums/...son-stock.html
On your 2013 Cayenne, how did you remove the stock side mirror?
Old Feb 1, 2013 | 06:23 AM
wwilliams88's Avatar
wwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of lightwwilliams88 is a glorious beacon of light
I used the method illustrated here:
http://www.toolworks.com/bilofsky/boxster/mirrors.html
This one was published in 1998, but doesn't look like things have changed much. Basically tilt the mirror as far down and towards the vehicle as it will go. I worked near the mounting point to get it to release which is more top than side. If needed, work a trim tool between the mirror back and the mount to get it to release. However, both of mine came off with steady finger pressure.
Old Feb 2, 2013 | 04:28 PM
nhirsch's Avatar
nhirsch is infamous around these partsnhirsch is infamous around these parts
Originally Posted by Harlequin NY
(by the way I never took LSD so its not that)
Rob
Then my observation won't be of any use to you in that regard.
Old Feb 2, 2013 | 10:00 PM
HA!
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
Goonie
Sep 13, 2015 02:26 PM
