Why A Diesel?
Old Mar 3, 2013 | 09:02 AM
  #46
grohgreg's Avatar
grohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of light
Simple. But first, understand that the chart I uploaded above is for the US-spec V6 diesel. Below is the chart for the US-spec Turbo S. I could find no comparable chart for the Diesel S, but the graphic next to it (from the Porsche UK website) has representative numbers.
So. Note that the Diesel S max torque is available between 2000 and 2750, and that the Turbo S max torque is available between 2250 and 4500 rpm. Short version, Diesel S max torque is available sooner. But the Turbo S max torque lasts longer. That's why the Diesel S will beat the Turbo S off the line. But the Turbo S torque has longer legs, which enables the Turbo S to catch up and eventually pass the Diesel S.
//greg//
Old Mar 3, 2013 | 12:16 PM
  #47
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
With my Unitronic tune I dynoed at 226HP and 402TQ to all four wheels. They rate the tune as 260HP and 483TQ at the crank so that is about right with a 15% drive train loss. Never heard of BlueSpark but those are some impressive numbers! Have you dynoed it yet?
David
Originally Posted by grohgreg
Absolutely, although I went the BlueSpark route. What kind of hp/torque does the Unitronic give you? I have my BlueSpark currently set up for about 288 hp and 496 ft-lbs
//greg//
Old Mar 3, 2013 | 12:27 PM
  #48
grohgreg's Avatar
Nope, closest possibility is a good two hour round trip. But I have a WiFi iOBD2 device coming next week that holds promise for some performance data.
Max torque from the BlueSpark is ~509 ft lbs, but it comes at the expense of some fuel economy. Max hp is 306, same trade-off. For reasons that are clearly over my head, there's not an actual 306/509 setting; you can have one or the other. Of nine settings available, what I've done is select the one that offers the most hp/torque with the most favorable fuel economy. There's one other with a little more torque but a slightly lower hp boost that suggests the same fuel economy. Gonna try that setting once spring arrives.
BlueSpark makes/sells four different boxes; Economy, Tech, Pro, Pro+Boost. I got the latter, which increases both common rail fuel pressure and turbo boost. Only guessing, but perhaps that's why the numbers are a bit higher than the Unitronic.
//greg//
Old Mar 3, 2013 | 12:58 PM
  #49
RedBent's Avatar
RedBent is infamous around these parts
Do these tunes void your warranty?
Old Mar 3, 2013 | 01:03 PM
  #50
grohgreg's Avatar
Nope. Service manager is fully aware of the tuning box. Besides, one of the nine settings is "off", which defaults to the factory 240/406
//greg//
Old Mar 3, 2013 | 11:17 PM
  #51
RedBent's Avatar
Originally Posted by Reborn996
This is my first diesel and one thing that excited me about it is that they are soo over built... diesels last forever with minimal maintenance. Heck, I still see old Mercedes diesels driving around town from 30 years ago. So when looking at the value, diesels seem to win the longevity award for ROI.
As for the power, I would recommend a tune like Unitronic. It really wakes up the 3.0 TDI motor.
David
I see those old diesel vehicles on the road as well and have heard that the run 200-300k miles pretty easily. While I understand that may be true with older diesel vehicles, I wonder if the same will hold true of the newer models since there are so many more electronics involved in today's car.
The more I read about these vehicles, however, the more I am liking the thought of purchasing one.
Old Mar 4, 2013 | 12:26 PM
  #52
binner's Avatar
binner is infamous around these parts
Don't have your dealer lend you one for 24hours like we did ... you will be ordering -- they are that impressive.
ash_cpe
Cayenne 958
16
Oct 3, 2016 08:02 PM
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
bzibi
Southwest
Sep 30, 2015 08:03 PM
