Break dust reduced 80%- ceramic pads
Old Dec 30, 2013 | 10:17 PM
SStyle's Avatar
SStyle is infamous around these parts
Do these aftermarket pads have the same pedal feel and stopping power as the oem ones?
Old Dec 30, 2013 | 10:43 PM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
the oe dust is crazy, i switched to ebc reds and am very pleased. also using sonax wheel cleaner is fun and works great.
Old Dec 31, 2013 | 04:29 AM
Harlequin NY's Avatar
Harlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of lightHarlequin NY is a glorious beacon of light
I am still not sure if the stopping power is the same or slightly decreased. It is more difficult to comment now since I switched to the winter wheels and tires and they feel different in every way. I am just so glad to be cleaning the wheels so much less.
Old Dec 31, 2013 | 08:15 AM
grohgreg's Avatar
grohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of lightgrohgreg is a glorious beacon of light
Ceramic pads are available for the base and for the Diesel, it's just that not all retailers carry them. Looks like these fronts may work, rears here.
//greg/
Old Jan 1, 2014 | 07:52 AM
WFBlue's Avatar
WFBlue is infamous around these parts
Originally Posted by NeunElf
Either you wear pads or you wear rotors. The energy must be consumed somehow.
There is no solution that will offer lower dust and either not give similar braking or consume the rotor.
Unfortunately, you speak the truth. I have been told (indie tech) that the ceramic pads are harder and produce less dust, but wear the crap out of the rotors. Interested to see how these work out long term for the OP.
Old Jan 1, 2014 | 08:15 AM
alvam63's Avatar
alvam63 is infamous around these parts
I just purchased my first Porsche, Cayenne, and yes the break dust is brutal. Is the conversion to PCCB really that expensive?
Old Jan 1, 2014 | 06:12 PM
BlazinPond's Avatar
BlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud of
Suncoast has them for $18.5k.
http://www.suncoastparts.com/product...=958v8ttbrpccb
Otherwise, its about $8800 option on a new vehicle order, above the standard brakes on Porsche's website.
Old Jan 3, 2014 | 06:07 PM
NC 997's Avatar
NC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant futureNC 997 has a brilliant future
Originally Posted by gnat
Should be the same pad options as the (non-PCCB) brakes on the V6 and S variants (Hybrid too?).
I'll give them a call. Perhaps the diesels Cayenne is new enought that they don't have it listed separately in their database
Old Jan 5, 2014 | 06:45 PM
howardhaoxie's Avatar
howardhaoxie is infamous around these parts
The brake dust is killer on stock pads! Will Sonax dissolve ceramic dust as it does normal ones?
Old Jan 7, 2014 | 06:40 AM
TheBeav's Avatar
TheBeav is infamous around these parts
Reviving this thread to ask whether anyone who switched to ceramic pads has experienced faster rotor wear. I would like a low dust solution, but given the cost of replacing rotors vs pads I wouldn't want that at the cost of new rotors every 20k miles.
Old Jun 20, 2014 | 12:18 AM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
Originally Posted by Harlequin NY
As The Big Easy experienced with his CTT, constantly cleaning the bake dust can drive you crazy. The black sports edition wheels are stunning but even after a short ride they get loaded with the dust and need cleaning. And there is a lot of surface area to clean on these wheels.
I decided to order ceramic brake pads for the red CTT brakes to cut down on the brake dust. I did the same with my SL500 a few years back which worked really well.
Tire Rack had pads from "Centric" and I had my mechanic put them on a week ago. The results are about an 80-90% reduction in brake dust. I am a happy rider. I was told that there might be a small reduction in braking power but I can't say I notice it yet.
Any new update on your pads? Will the Centric pads also fit a 958 GTS?
I'm real tired of the dust. Thanks.
Old Jun 20, 2014 | 07:53 AM
I feel your pain. It has been a longer time since I had the original pads on and I can't say for sure if there is a reduced braking result or not. I am guessing that the braking power is a little decreased but I am really happy with the minimal brake dust.
I don't know about the compatibility for GTS but you can go on tire rack and see which Centric Ceramics fit yours. I think this is the one I got:
http://www.tirerack.com/brakes/brake...oModClar=Turbo
Old Jun 20, 2014 | 06:05 PM
NeilM's Avatar
Is it a simple swap or are there complications? Thinking of just doing it myself.
Old Jun 20, 2014 | 08:00 PM
sighting's Avatar
sighting is infamous around these parts
I just got the EBC yellow ones and they are an substantial upgrade over the stock ones.. from both a performance and dust perspective
Old Jun 21, 2014 | 07:31 AM
My mechanic who owns a GTS did them and it seemed straight forward. I think they accidentally broke a wear sensor on one so be careful with that.
