OEM Back Up Camera
Old Nov 4, 2014 | 03:26 PM
  #46
Sc00ter's Avatar
Sc00ter is infamous around these parts
The parts you mentioned @G_A , are only Audi or VW as well ? Apart the Porsche ones. Tks
Old Nov 5, 2014 | 08:15 AM
  #47
mmdht2's Avatar
mmdht2 is infamous around these partsmmdht2 is infamous around these parts
Originally Posted by Sc00ter
Do all of you have PCM ?
What about no PCM --- rear view camera installation. Would it be possible?
look at G A's post. the pic he provided is for a non-PCM.
Old Nov 5, 2014 | 01:42 PM
  #48
Sc00ter's Avatar
^^Tks, but I can't see any pics of the rear of the unit.
Originally Posted by G_A
no!
You do not need this.
You need piwis2 to make coding, but guys with piwis do not need this video))
Question for you @G_A. So I have a 2014 with no PCM.
I tried the coding and it allows me to select "parking sensors + camera LOW".
After coding , sensors still work fine.
Does this mean I can buy an OEM camera + wiring and add it on and it will work fine? Using your code parts I won't be missing nothing ?
Tks a lot
Old Feb 14, 2015 | 01:25 PM
  #49
mmdht2's Avatar
after several months trying to source oem parts and finding a dealer willing to code the pcm without much success, i decided to order and install this myself:
http://www.ebay.com/itm/360957649921?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AITshipping was crazy fast from europe to east coast (even including a 2 day custom delay). the rear camera is a perfect replacement to the trunk lift. super easy install with this video on youtube:
Jorge from worldwidesounds is incredible in helping me during the install. he installed wechat on his phone just to help me in real time.
the only hiccup is the instruction and video forgot to mention that you need to remove the fiberoptic cable from the old wiring harness to the new wiring harness so i didn't have sound and access to jukebox after the install-Jorge troubleshot it right away.
the biggest annoyance is the lack of direction lines in the video but that's impossible to get without an actual porsche camera.
i can probably do the whole install in 1hr now. the most difficult/scary part is to remove/reinstall the shell of the trunk. this tool helps:
http://www.harborfreight.com/6-piece...set-66188.html
overall, i think it's money well spent. again, highly recommend this ebay seller.
ps. i think it also does video in motion.
Jun 10, 2017 07:45 PM
turbotuner20v
Sep 11, 2015 12:02 PM
pwdrhound
Aug 23, 2015 07:36 PM
Lifeisgood2
Aug 19, 2015 10:02 AM
