Very strange problem on my Cayenne S
Old Apr 9, 2014 | 03:24 AM
  #31
TGED's Avatar
TGED is infamous around these parts
My speakers also are not cutting out since the weather starting to warm up. Still no definitive solution from Porsche, but now any repair cannot be verified until Oct/Nov.
Old Mar 14, 2017 | 12:49 PM
  #32
sjg1138's Avatar
sjg1138 is infamous around these partssjg1138 is infamous around these parts
Reviving an old thread here.
I noticed that the sound from the stereo in my 2011 S cuts out momentarily when the Stop-Start re-starts the motor.
Anyone come across a fix for this?
Old Mar 14, 2017 | 01:52 PM
  #33
TGED's Avatar
There is no fix and I noticed the same problem also happened to some of the Cayenne loaners.
Old Mar 14, 2017 | 04:29 PM
  #34
958 S's Avatar
958 S is infamous around these parts
I cannot imagine it is anything other than a lack of proper voltage, and batteries are less efficient at lower temperatures. Most problems related to audio come down to lack of power or a grounding issue, I highly doubt it was a grounding issue as that would not be related to only the auto start stop. That feature uses power to varying degrees depending on what is running, and amplifiers take a decent amount of power, sufficient power.
Now my soapbox. Quite honestly I turned the feature off when I test drove the Cayenne and have never turned it back on. It is an annoying nanny state feature meant to boost fuel economy specs all while creating more wear and tear on many other system components to restart the engine every time.
Old Mar 14, 2017 | 06:59 PM
  #35
TGED's Avatar
They have tried the following which did not solve the problem, swapped the PCM with one from another Cayenne which did not have the problem, replaced the starter motor, battery, power invertor, running an extra cable from the power supply to the PCM.
They have given up and I have stopped using the auto start stop feature.
PV=nRT.
Sep 9, 2022 06:06 PM
dgreen78
Feb 29, 2016 11:28 PM
Yellopeter
Cayenne
Oct 9, 2015 11:20 AM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
