Auto start/stop
Old Jan 25, 2014 | 07:08 AM
super50's Avatar
super50 has a spectacular aura aboutsuper50 has a spectacular aura about
Auto start/stop
This function does not seem to work in my 958 - are there any tricks to it?
Old Jan 25, 2014 | 09:21 AM
TTCarrera's Avatar
TTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of lightTTCarrera is a glorious beacon of light
Per the owner's manual, when you drive in Sport mode the Auto Start/Stop is disabled.
Also, if you push the AS/S button and the red light goes ON, that means it's disabled (counterintuitive).
Check those and if it still doesn't work, take it to the dealer.
Old Jan 25, 2014 | 11:36 AM
BlazinPond's Avatar
BlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud ofBlazinPond has much to be proud of
TTCarrera's right on...
Also, one more item to note is that if the temp is above or below a certain threshold it also will be disabled - if I recall correctly.
Old Jan 25, 2014 | 01:34 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Hopefully not to state the obvious, but you don't have a diesel or 6MT do you? AS/S isn't on either of those configurations.
Old Jan 25, 2014 | 03:50 PM
super50's Avatar
Great! Thank you. I will try it out.
Mostly my driving has been in sport mode, so maybe thats it.
Also, I had the little red light on the switch on, so I will turn it off and see!
matt2ace
Nov 23, 2019 11:38 AM
jabed92694
Apr 3, 2016 11:31 AM
Porsche246
Oct 10, 2015 04:02 PM
