Audio Default Question
Old Nov 22, 2014 | 06:03 PM
GFORCED's Avatar
Built to Blast
GFORCED has much to be proud ofGFORCED has much to be proud ofGFORCED has much to be proud ofGFORCED has much to be proud ofGFORCED has much to be proud ofGFORCED has much to be proud ofGFORCED has much to be proud ofGFORCED has much to be proud of
My radio on my 2014 Cayenne S is defaulting to a Mexican radio station. If I'm listening to satellite radio and then turn the car off, it defaults to an AM station. Can someone tell me how to default to the last station I was listening to like most other cars do? Thanks!
Old Nov 22, 2014 | 07:30 PM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
Sounds like a trip to the dealer.
I rarely use the radio (read only when the usb isn't recognized), but its always on the same station when I do.
I have a 2013, but I doubt that changed.
Old Nov 22, 2014 | 11:46 PM
GFORCED's Avatar
Built to Blast
Has to be a simple fix. I bet there's someone that can tell me... Anyone??
Old Nov 23, 2014 | 02:01 AM
Average Joe's Avatar
Average Joe is infamous around these parts
It may be programmed to your key with your saved settings. Try re-saving with the SAT turned on.
Old Nov 23, 2014 | 10:38 AM
GFORCED's Avatar
Built to Blast
No info online on how to program a key. It appears a device is needed for that that the dealer has.
Old Nov 23, 2014 | 11:36 AM
No, it is part of the Comfort Entry and Memory Function. Look in your manual.
When I enter with my key, my preferred sat channel is automatically on; and if my wife enters with hers, it is automatically on her preferred channel.
It is an automatic function. You need to save your seat setting on the door with everything set up the way you want and it saves that info for that key. It saves everything; the Temp settings, the display settings, and even the radio station.
If you select "comfort entry" in the settings/locking menu it will save whatever is currently set every time you exit the car.
Old Nov 23, 2014 | 12:24 PM
GFORCED's Avatar
Built to Blast
Great info! Thanks Average Joe will check it out! Thanks.
cnebrask
Oct 3, 2024 08:19 PM
Money2536
Jan 19, 2022 08:22 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
RallyBird
Oct 7, 2015 01:20 PM
nreddy
BMW //M
Aug 26, 2015 11:42 AM
