How Do I Set Dipping Mirror For Reversing?
Old Feb 19, 2015 | 02:32 PM
carlosC4S's Avatar
carlosC4S is infamous around these parts
Hi all
Can somebody help, I can't seem to get the passenger side mirror to dip when reversing, the function is on in the settings but it doesn't drop, I have memory seats, do I need to set it as part of the seat settings as well?
I recall doing something like putting the gearbox into reverse, adjusting the mirror to the dip I want then pressing the memory button to set it when I have my 955 CTT but that doesn't wot in my 958 CTT so how does it wot please?
Manual doesn't help past saying activate the setting?
Old Feb 19, 2015 | 02:52 PM
HOiYA's Avatar
HOiYA is infamous around these parts
It's in the PCM. I don't recall the exact screen, but I think it is parking aids or something like that.
Old Feb 19, 2015 | 03:07 PM
Robotpedlr's Avatar
Robotpedlr is infamous around these partsRobotpedlr is infamous around these parts
On the 2015 it is in the vehicle set up menu under Lights & Visibility then Reverse opt.
Old Feb 19, 2015 | 03:36 PM
carlosC4S's Avatar
I've ticked that box but no joy and can't see anything in the PCM manual?
Old Feb 19, 2015 | 05:26 PM
Robotpedlr's Avatar
Does it dip when you press the button on the door arm rest to manually activate the dip? That would tell if the motor is toast.
Old Feb 19, 2015 | 08:34 PM
C4SxM5's Avatar
C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !
On my 12 and 13 the mirror button needs to be pushed to the right so it's on the passenger mirror.
Old Feb 20, 2015 | 05:55 AM
gnat's Avatar
gnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant futuregnat has a brilliant future
The PCM/MFD setting should be all you have to do. Are you giving it enough time? Mine is so slow that I can have backed out of my spot and started forward before it's finished moving, which of course ends up with it stuck in a bad position. I disabled it on mine and just check my passenger side as I approach the car.
Old Feb 20, 2015 | 04:18 PM
kechang's Avatar
kechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to beholdkechang is a splendid one to behold
like someone mentioned already, when in reverse, press the "right" mirror switch and see if it tilts down
if not, most likely something is wrong
Jul 29, 2019 11:13 AM
no1joey
Sep 2, 2015 12:32 AM
The Oss
Aug 24, 2015 08:19 PM
silver86
Cayenne 958
Aug 21, 2015 03:08 PM
Aug 19, 2015 06:35 PM
