Wheel bolts cover installed
Old Nov 25, 2015 | 03:03 AM
hkb5variant's Avatar
hkb5variant has a spectacular aura abouthkb5variant has a spectacular aura abouthkb5variant has a spectacular aura about
The 4 lock bolts which are notorious for being easy to get damaged, are replaced with normal bolts but they have different color from the rest bolts.
just covering them with the same color bolt covers
Old Nov 25, 2015 | 08:26 AM
jhbrennan's Avatar
Looks nice and clean. Curious about locking lugs easy to damage? And also, what were the color differences?
Old Nov 25, 2015 | 08:48 PM
The groves and walls inside the Porsche lock lug are too thin and delicate to damage when bolting/unbolting with slightly over torque.
All the stock wheels bolt were in black. One of my 4 lock lugs has damaged during wheels changing.
I ordered 4 pieces of normal bolts to replace the 4 lock lugs but they came in silver color which doesn't match with the rest black normal bolts.
Old Dec 2, 2015 | 07:16 AM
jab23's Avatar
jab23 has a spectacular aura aboutjab23 has a spectacular aura about
So, these are just covers that snap on to the lug bolt heads? My winter wheels are grey and my lugs are black. This would be a great solution. Can I ask where you got them? Thanks!
Old Dec 2, 2015 | 03:47 PM
garymyman's Avatar
garymyman is infamous around these parts
OP can correct me, but these look pretty darn close:
http://www.amazon.com/Nickel-Covers-Extraction-Perfect-Mercedes/dp/B00KMA0S6Y/ref=pd_sim_sbs_293_10?ie=UTF8&dpID=31lj1v18UbL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1AXSKKGBHCE0AA5PBWA4 http://www.amazon.com/Nickel-Covers-Extraction-Perfect-Mercedes/dp/B00KMA0S6Y/ref=pd_sim_sbs_293_10?ie=UTF8&dpID=31lj1v18UbL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1AXSKKGBHCE0AA5PBWA4
I searched amazon for 19mm lug bolt covers
Old Dec 2, 2015 | 04:53 PM
jhbrennan's Avatar
Originally Posted by garymyman
OP can correct me, but these look pretty darn close: http://www.amazon.com/Nickel-Covers-...GBHCE0AA5PBWA4
Our tested & proven lug covers fit extremely firm once installed to prevent loosening even under extreme driving
Keep it under 150 mph and they should stay on
Old Dec 2, 2015 | 08:16 PM
What I bought are the OE Audi ones for Q7: 4L0 601 173 Z37
Please note that caps for lock lugs are different one.
You need 4 of them if you are using lock lugs in your car.
All caps need a special clip to remove from lugs
Old Dec 3, 2015 | 02:02 PM
westsiderkg's Avatar
westsiderkg is infamous around these parts
I just bought the tpi set. Hope they fit as well. Will report back for others.
alwaysnboost
Dec 2, 2015 04:17 PM
steve.rinaldi
Nov 23, 2015 07:04 PM
kar
Cayenne Turbo
Nov 23, 2015 04:44 PM
DB-Design-Group
Nov 22, 2015 12:41 AM
Street Fighter
Nov 20, 2015 09:36 PM
