Is it Possible to Change the Tail light from cayenne 958.1 to 958.2 ?
Old Aug 11, 2016 | 10:37 AM
boxs1's Avatar
boxs1 is infamous around these parts
Thanks in advance
Old Aug 11, 2016 | 10:40 AM
Griza's Avatar
Griza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud ofGriza has much to be proud of
Doesn't look like the same shape so without some major work probably not.
Old Aug 11, 2016 | 11:24 AM
Michael_s's Avatar
Michael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant future
I like the .1 better.. I know not too helpful but....
Old Aug 11, 2016 | 03:13 PM
spyderman33's Avatar
spyderman33 is infamous around these parts
its highly unlikely or not worth the colossal amount of money it would take to do it.
Old Aug 11, 2016 | 05:59 PM
amablemiguel's Avatar
amablemiguel is infamous around these parts
If I recall it can BUT you'll need a 2015-16 rear bumper with all covers, complete Tailgate, roof spoiler and obviously the lights. Not going to be cheap.
Old Aug 11, 2016 | 06:01 PM
count me in... I do like more my 11 smoked tail light than the new, even the light arrangement is more beautiful.
Old Aug 11, 2016 | 11:48 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Ditto.. I keep mistaking the new arrangement for something Japanese...
Old Aug 12, 2016 | 12:19 AM
boxs1's Avatar
The 958.2 rear Bumper looks more completed and the taillights makes the car look more wide and more high
Old Aug 12, 2016 | 12:21 AM
boxs1's Avatar
maybe i will need new Hood new Bumper and smoked LED but not sure should i buy a new Control unit for the tailights
Old Aug 13, 2016 | 09:01 AM
for the front is a different story my friend. The LED lights is not just a swap you'll need a new module for the lights.. Add to that the complete bumper with grilles, new fenders and new hood plus all 2015-16 engine covers. Again better to buy a whole used cayenne if you want to save.. You're heading north of 15k in parts....
Old Aug 13, 2016 | 09:22 AM
One can DO almost anything given an endless supply of money. Should one do it? Well - when the cost starts exceeding the value the answer is simple. Nope.
Old Aug 13, 2016 | 09:40 AM
I agree. That's what I meant. I'm the best example I installed the 15-16 steering when Porsche says it can't be done. I'm starting Monday the install of Entry and Drive when Porsche says it can't be done. I installed the rear camera with dynamic guidelines and a front camera when Porsche says IT CAN'T BE DONE.
There is no never or NO when modifying your car. Talk to me, that I know of.
Old Aug 13, 2016 | 10:14 AM
boxs1's Avatar
How did you install the front camera
I need to Upgrade the back of the car btw
Old Aug 13, 2016 | 10:50 AM
How did you install the front camera I need to Upgrade the back of the car btw
if you have PCM3.1 (NOT CDR31) then you need this, it will activate DYNAMIC GUIDE LINES:
https://www.amazon.com/gp/aw/d/B01JVK4NHK?vs=1
It comes with a second RCA input which is for a front camera and you do not have to program anything. To activate the front cam you hold NAVI button for about 5 seconds. This works on P N and D not on Reverse because the rear camera takes control obviously.
Get a rear handle camera for the cayenne preferably with a Sony sensor and be sure it has guide lines. Also for the front a camera use something like this
https://www.amazon.com/gp/aw/d/B00RD...SeL&ref=plSrch
I'm out right now but here is the front camera I got from eBay.
http://m.ebay.com/itm/121150021490
Has an amazing resolution and a Sony sensor. It has 2 cables, white and green, white for mirror camera function which I did not bother with but I did cut the green cause I don't need guide lines for the front.
Old Aug 22, 2016 | 04:11 AM
boxs1's Avatar
Thank you will check it out but the one on the amazon looks little expensive
