Air-con draft issue!
Old Mar 21, 2020 | 10:16 PM
samuell's Avatar
5 Year Member
samuell is infamous around these parts
Hi Guys,
In the past few days, I have observed that the draft from the Air-con system on my 958.1 S isn’t fine.
It’s a RHD car and the right most (Driver’s side - near the window) has minimum draft even if the fan setting is on full.
Also, when the Air-con is on, the draft on the front passenger side footwell gives out draft as if its with the Aircon off.
Hoping a cayenne specialist on this forum might be able to help :-)
Old Jun 19, 2020 | 12:11 PM
Scrotius's Avatar
Scrotius is infamous around these parts
Have you replaced the cabin air filter recently or adjusted it?
There is a plastic pipe that must be seated and directs airflow between the blower motor and cabin air filter. If the pipe isn't installed correctly then the blower motor will just be blowing air directly into the footwell.
Check that out and feed back
Old Aug 2, 2020 | 10:36 PM
TJtheDJ's Avatar
TJtheDJ is infamous around these parts
I just did the cabin air filter swap today and can confirm this issue as well. My pipe was dislodged from the clamp. After replacing the filter and resetting the clamp from the plastic pipe in the correct location all is well. Man those cabin filters get filthy!!!
TGED
Cayenne 958
34
Mar 14, 2017 06:59 PM
cayou31
Cayenne
Jun 7, 2014 07:18 AM
Nate Gabbana W
Cayenne
Jul 23, 2012 08:27 AM
racerja
Cayenne 955/957
Feb 1, 2012 06:19 PM
TT
Cayenne 955/957
14
Aug 30, 2004 09:42 AM
