Blinkers and Headlights Failing in Cold Weather
Old Nov 24, 2020 | 09:29 AM
MyBlueBetty's Avatar
MyBlueBetty is infamous around these parts
So my '15 Cayenne S has been having issues that the dealer can't seem to figure out. Symptoms are all blinkers (front and rear) and driver low beam fail when the outside temperature is below 55F. Once the car warms up to operating temperature, the headlight and blinkers all miraculously function again. A few nights ago I discovered a new symptom which seems to be sporadic; with the temperature below 50F and my headlight switch turned to OFF, my LED DRLs began to blink on and off. Last year I had an issue where only my driver headlight would "freak out" and would flash rapidly sometimes, work other times, or just stay completely dead. Dealer blamed it on a "rogue screw that cracked the headlight housing" (to this day I have not found the crack but fully siliconed the perimeter of the headlight housing anyway) and replaced the headlight module (for $750). Seemed to do the trick until this year along with the new symptoms.
Has anyone experienced this behavior before or have any suggestions on what may be causing the issue? I'm still under my CPO warranty but can't seem to get a real resolution from the dealership... Any help is appreciated!!!
AU M5
Sep 16, 2013 01:22 PM
MaLau
Cayenne 958
Dec 24, 2012 05:51 AM
BLKPPR
Cayenne 955/957
May 16, 2011 11:15 AM
TurboRx
Jul 24, 2007 08:42 AM
andreas
Lamborghini
Dec 6, 2005 12:33 AM
