Cayenne won’t start/random error messages on instrument cluster
Old Oct 17, 2022 | 08:33 PM
Tim91492494498795's Avatar
Tim91492494498795 is infamous around these parts
I have been getting intermittent non-start issues. I turn the key and nothing. All electric works like radio and windows and headlights. But the engine will not crank. Displays “random” error messages in cluster that are not stored.
Car was towed to the Porsche Dealer who said probably low voltage from an old battery. I paid big dollars to replace it even though the current battery was only 18 months old.
For months now I still have the same intermittent non-start issue. I always get multiple error codes, however not all the same error messages with each non start occurrence. Such as start stop deactivated, fault headlight control, PASM, coolant display defective, oil temperature display defective
It usually starts again after a few hours or next day. I pulled carpets and no sign of water or corrosion.
The car always starts when I bring it to the dealer of course, but the Dealer has ran a couple of test and no errors are ever stored in the computer. They said without error codes they can’t figure out what’s going on. I ran my icarsoft scanner when it happened in my driveway, and got literally dozens of error codes :-) however when the car restarted the following day no error code were officially stored.
Any thoughts on how to fix or if anyone had had a similar problem please let me know. 2012 Cayenne V6 130,000 miles. Absolutely no issues other than this in the past five years of ownership.
Old Nov 16, 2022 | 07:59 AM
toddperk's Avatar
toddperk is infamous around these parts
hello.
I'm having the same problem with my 2012 Turbo. Do you have any thoughts or update? could it be the starter?
Old Sep 4, 2024 | 07:08 AM
Did you ever get it fixed? What did you do?
i’m getting the same problems. I’ve been struggling with it for 18 months. Exactly as yours Dealer can’t solve it either. How did you get yours fixed??? Thanks for replying!
Old Feb 24, 2025 | 01:23 PM
Gazrich_uk's Avatar
Gazrich_uk
Update?
Did anyone solve this issue, I've got the same issue
newporsche
Dec 18, 2021 09:52 PM
das555
Apr 25, 2017 06:17 PM
EMC2
Cayenne 955/957
Sep 7, 2015 05:20 PM
wmiranda
Jan 23, 2015 09:08 AM
pat
Cayenne
Jan 14, 2013 11:55 PM
