Cayenne Turbo All Cayenne Turbo model topics
Metal coolant pipe tee?
Old Aug 10, 2016 | 04:45 PM
markdjr's Avatar
markdjr is infamous around these parts
It's been awhile since I've looked, did anyone ever source an alternative to the plastic tee for the coolant pipes? Thanks for any info.
Old Aug 11, 2016 | 06:53 AM
bfly88's Avatar
bfly88 is infamous around these parts
How worried are you about it failing? I replaced mine around 120K miles only because I had everything apart to replace the plastic coolant pipes. There was nothing wrong with the 'T' fitting when I pulled it out.
Now, removing the 'T' fitting SUCKED! There isn't a lot of room to get your arm in there to remove the fitting. Make sure you get one of these:
Old Aug 17, 2016 | 02:46 PM
Mr. Haney's Avatar
Mr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to beholdMr. Haney is a splendid one to behold
Jagsthatrun has them. Very nice. Under cooling system parts.
Old Aug 29, 2016 | 01:07 PM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
I installed the Jagsthatrun on mine and were very happy with them. I don't remember off hand what sizes I used but you can check my youtube video as it should be listed in there if you need to know. The nice thing about the metal T's is you will never have to do this repair again!
Old May 22, 2018 | 10:09 PM
jdubbya's Avatar
jdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to beholdjdubbya is a splendid one to behold
Judging by watching your video it looks like one is 1" base and 3/4" branch. The other looks like 3/4" base and 3/4" tee.
I just realized you were the same dude that I've been watching on how to take my '05CTT apart because it puked the coolant last week. Pretty sure it's the driver's side tee on mine that went as that's where water is still leaking.
Have been waiting on parts and then I saw this about metal tees. I just ordered them, hopefully they can ship quickly. I need my ride back.
I somehow never put you and the youtube channel together. Thanks a million for the help, I've just about got the intake off and ready to replace whatever is broken!! The one thing you didn't mention is how you relieved the fuel pressure. I'm going to use the valves on the end of the rails. Is there a bleed procedure when hooking them back up?
Old May 28, 2018 | 02:40 AM
jdubbya's Avatar
Wow was this job is a major pain in the ***!! All back together but I will never do that one again.
That bottom clamp is nearly impossible to reach even with the cable pliers. I already had a pair but they actually started breaking you have to pull so hard to get the clamp spread far enough apart to get over the nipples. I ended up having to run to Sears to get a new pair. Worked much better.
MichaelB1969
Feb 17, 2026 03:29 PM
8ighty1ne
Feb 25, 2018 06:11 AM
wquiles
Jul 31, 2016 06:08 AM
Oversight
May 24, 2016 10:39 AM
Akatsuki...
May 23, 2016 01:39 PM
