Cayenne Turbo All Cayenne Turbo model topics
Torque converter shudder after trans fluid change
Old Dec 17, 2019 | 08:56 PM
Juniorkusch's Avatar
Juniorkusch is infamous around these parts
Hello and thank you. New to this forum and to a 2004 cayenne 4.5TT, 3rd owner w/ 100,000. Replacing fluids and filters, saved the tranny(aisin TR-60sn) for last. Removed pan, filter and 7.5L of still good oil. Cleaned pan and magnets. Was able to re-fill 7.5L of aisin type T-IV fluid. Shifts great in all gears, but now has a shudder at W.O.T.. From the T.Q. since it ran fine before. Theories
#1 Cavitation, o-ring not seated on trans filter.
#2 Differences in fluid, didn't put in "Porsche" fluid but trans maker OEM spec.
I'm going to re-do the re-fill and check the o-ring but WHAT FLUID? Thank you, kindly
Old Jul 26, 2020 | 01:39 AM
gibbsy's Avatar
gibbsy is infamous around these parts
Tranny oil
Mobil ATF 3309
or toyota type 4.
Reason it is shuddering is it needs the torque converter flushed when fluid is changed.
Tranny holds 9.6 litres.
usually you change the oil and then flush the torque converter until all is clean.
just completed mine yesterday and went through 10.8 litres.
Now smooth and responsive.
blackonblack996
Apr 21, 2017 03:15 PM
RoyC
Cayenne Turbo
Sep 6, 2016 11:20 PM
E.C.
Cayenne 955/957
23
Feb 24, 2015 11:05 PM
Brooklyn boosting
Jan 27, 2015 01:01 PM
