Automatic headlights and resetting oil change reminder?
Old Dec 22, 2008 | 12:00 PM
B Feelgood's Avatar
B Feelgood is infamous around these parts
I can't for the life of me figure out turn on the auto on/off headlights. I have a 2005 Cayenne turbo and I assume that it has them because it has the homelink and lights in the bottom of the mirrors. I know where to turn them on manually, is it in the same place? How do I activate them or find out for sure if the vehicle is equipped with them?
Is there a way to reset the oil change service light reminder yourself? I just changed the oil myself but do not know how to reset the reminder. My dealer said they charge $71 to do this, which seems absurd seeing as how it could not take more then a few minutes.
Old Dec 22, 2008 | 12:04 PM
///M Kevin's Avatar
///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold
My reminder for a tune up has been lighting up lately. I'm curious myself.
Old Dec 22, 2008 | 03:28 PM
DEFILER's Avatar
DEFILER is infamous around these parts
Insert the key in the ignition but do not turn it.
Hold down the trip reset button on the cluster and while holding it in turn the ignition to the start position without touching the brake pedal.
The display will show "Service Reset" When you see this message click the confirm/enter button on the bottom of the wiper stalk 1 or 2 times.
That should do it.
Chris
Old Dec 22, 2008 | 04:14 PM
///M Kevin's Avatar
That should do it.
Chris
Chris, thanks for your help.
Old Jan 4, 2009 | 06:51 PM
mpatrizio's Avatar
mpatrizio is infamous around these parts
That should do it.
Chris
This should be made a sticky.... Great info.
Old Jan 5, 2009 | 10:36 AM
///M Kevin's Avatar
I've been getting a "Service Now" message on my dash? Does anyone know if this is a required service or is it just a reminder for an oil change? I have 6200 miles.
Old Jan 7, 2009 | 09:57 PM
///M Kevin's Avatar
I tried doing that an hour ago but it didn't reset my "Service Now" message. Is it different on 997?
Old Jan 8, 2009 | 08:17 AM
tonga3's Avatar
tonga3 is infamous around these parts
You can get a durametric tool to reset it.
Old Jan 8, 2009 | 10:05 AM
///M Kevin's Avatar
Is that something you can get at a local car part store or this strictly Porsche Service Dept?
Old Jan 8, 2009 | 10:28 AM
tonga3's Avatar
Old Jan 8, 2009 | 11:16 AM
///M Kevin's Avatar
Thank you for the link. It's funny how it includes 997 and 997 TT but it doesn't list 07-08 997 GT3.
Old Jan 8, 2009 | 01:16 PM
canberk's Avatar
canberk is infamous around these parts
it unfortunately doesn't list >'08 Cayennes either...
Old Jan 8, 2009 | 01:19 PM
///M Kevin's Avatar
So is this one of those things that you can't reset from inside your car?
Old Jan 10, 2009 | 03:47 PM
///M Kevin's Avatar
Bump for answer...
Old Jan 10, 2009 | 04:35 PM
tonga3's Avatar
As far as I know you can't reset it from inside the vehicle unless you take it to a dealer or use a durametric.
