Anyone know how to remove the entire ashtray on my 05 S?
Old Sep 3, 2010 | 04:31 PM
roxboxxx's Avatar
roxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant future
It broke on the Midnight run while agressively pulling out my radar detectors power cord. When I close it, it wont catch and just slides open again. Anyone know how to pull out the entire assembly? I am sure I can fig it out, but why waste time
Old Sep 3, 2010 | 09:20 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
Remove the horseshoe trim around the radio, depress the little spring tabs to pop out the A/C control head (a 90 degree pick works really well, just insert and twist), then you will see (2) T20 torx screws to remove.
Old Sep 3, 2010 | 09:45 PM
roxboxxx's Avatar
PERFECT - thanks, will hit it first thing tomorrow.
Old Sep 6, 2010 | 12:54 PM
CayenneExpress's Avatar
CayenneExpress is infamous around these parts
Thanks for posting. I removed it last night because it had been stuck. After pulling it out I found three coins stuck under the ashtray. Now it works like a charm and I'm 16 cents richer!
Old Sep 6, 2010 | 06:36 PM
roxboxxx's Avatar
LOL - Mine was a quarter !!!! All fixed now.
Old Sep 7, 2010 | 02:27 PM
Nice, we're both considerably richer now. Thanks to speed demon!
Old Sep 7, 2010 | 03:15 PM
roxboxxx's Avatar
If we pool our money we might be able to split a half eaten sandwich. You down for that? Baloney OK?
Old Sep 7, 2010 | 07:32 PM
No problem. Maybe if you all buy ME a sandwich!
Old Sep 7, 2010 | 09:03 PM
roxboxxx's Avatar
Actually - completely forgot. I removed my sub last month as I dropped a bunch of fuses down in the well and they were rattling around. Here is what I found UNDER the sub all green and stuck to the floor pan.
Old May 8, 2011 | 02:16 PM
scott_fx's Avatar
scott_fx is infamous around these parts
can someone help me. i can't seem to figure out where the spring clips are when trying to remove the a/c controller
this is where i'm looking:
http://onfinite.com/libraries/1676291/7ee.jpg
Old Oct 14, 2011 | 10:31 PM
echodeltoid's Avatar
echodeltoid is infamous around these parts
AC controller clip locations
I cant find the clips either. Does anyone know more about this? a pic would be awesome. (thru a microscope probably, right?)
Old Sep 22, 2012 | 10:13 AM
James Lightfoot's Avatar
James Lightfoot is infamous around these parts
This foxed me for a while. I took these 2 pictures. You can see the clip when removed, and you can just see the silver vertical edge when the unit is fitted (circled).
They needed a good push inwards with a flat screwdriver to unclip (the blade would be pushed against the left of the clip in this picture).
NIKAS
Aug 20, 2019 07:53 PM
markj
911
Apr 7, 2016 05:44 PM
jaehoppa
Oct 22, 2015 09:17 PM
