Coolant Leak
Old May 1, 2012 | 11:02 PM
atp160's Avatar
atp160 is infamous around these parts
Coolant Leak
Hello All,
Driving down the highway today and my add coolant light comes on. Good thing it was my exit and had to only drive a mile. The temperature gauge never moved off of 180. Pulled into my driveway and there was coolant leaking out of the bottom. Took down the skid plates but it was getting dark so I couldn't see anything. What has been everyone's past experience with this? I know there are multiple scanerio's. I do remember that the main coolant lines under the intake are plastic and go bad and that the replacement part is aluminum. Go figure just put it up for sale. Thanks for the info.
Respectfully,
Old May 2, 2012 | 01:06 AM
BLKPPR's Avatar
BLKPPR is infamous around these parts
I just went through this. Take a hose and run it under the plenum. Don't shove it in there just put it in and turn the water on gently after the car has cooled. Try not to soak any electrics. This should hopefully rinse out most of the residue. This should hopefully prevent the starter from just getting soaked by coolant and eventually ruining it.
Don't drive the car. Have the dealer flat bed it to the shop or to your indy. The pipes will have to be replaced.
Old May 2, 2012 | 08:12 AM
atp160's Avatar
Thank you.
Old May 2, 2012 | 09:45 AM
ECS Tuning - Porsche's Avatar
I would say, most likely it is your coolant pipes, as BLKPPR said. There are prone to failure in the S and Turbo.
We carry the full coolant pipe kit, which includes all new pipes, gaskets, and coolant.
If you have any questions, don't hesitate to PM me.
Old May 31, 2012 | 01:10 PM
zzzx's Avatar
zzzx is infamous around these parts
change the T too while you are there. mine was the T snapped.
Old Jun 2, 2012 | 08:30 PM
atp160's Avatar
Bought the kit from ECS Tuning. Plastics pipes broke off into the thermostat housing and the big one broke off into the back of the engine. Pane in the butt to get out but everything else was straight forward. The instructions that come with the repair kit are for a turbo. Mine was an S so my battery was under the spare not under my seat. Pretty straight forward. Thank you ECS Tuning very much, you guys saved me $1300 bucks.
Old Jun 3, 2012 | 03:38 AM
ez1973's Avatar
ez1973 is infamous around these partsez1973 is infamous around these parts
Approximately how long did this process take you? Is this something someone could do at their home garage, and how difficult would you rate the process on a scale of 1-10? Thanks...
Old Jun 4, 2012 | 05:50 AM
Glad we could help! Did you do the operation at home, or did you have the luxury of a lift?
Thanks for the vote of confidence, we're glad to help anytime!
Glasgo
Nov 30, 2015 02:37 PM
freddiemac
Oct 7, 2015 11:05 AM
flewis763
Oct 4, 2015 04:14 PM
