05 headlite goes off help please
Old Jun 15, 2012 | 07:39 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
ok guys i need some help my wifes 05 cayenne has a headlite prob.... when i remove the complete unite it will work for a day or two and then it goes dark ... this seems to happen with the riders side lite from time to time also.... when i remove it i spray it with elec cleaner that i have used on my maf on the996tt..... any ideas would be great thanks in advance steve
Old Jun 19, 2012 | 09:00 AM
BLKPPR's Avatar
BLKPPR is infamous around these parts
Steve,
I had the same issue when I took my lights out for bulb replacement. I realized I wasn't locking them in all the way. You have to push the headlight in while turning the tool until you hear a distinct "click" almost feels like you are going to break it but it just has to lock in place or it basically jiggles itself loose enough to lose connection
Old Jun 19, 2012 | 07:42 PM
thanks i'll give it a try
Old Jun 21, 2012 | 05:19 AM
BLKPPR's Avatar
Steve,
Did it work?
Caesar
Old Jun 21, 2012 | 06:43 AM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
i had a balLast go bad so i was round and round with those lights.
the tips i learned are as follows
a dry main connector does not dig going together, so lube up the rubber a bit.
dont use cleaner on the connections, use deoxit, a cleaner/protectant
if its the main beam thats messing up and you do need a ballast search the number
on ebay, several other cars use the same one, or pay a stealership 450$
Old Jun 24, 2012 | 06:48 PM
BLKP still not working works for a short time then not at present turn sir gone and headlite diped sign comes on thanks for the help steve
Old Jun 24, 2012 | 06:52 PM
am thinking if it's the ballast they would not work at all , yep they the right headlite did the same thing but now works fine lucky we don't get out much at dark
Old Jun 24, 2012 | 06:53 PM
cuemaster's Avatar
dipped beam, its ballast time.
Old Jun 25, 2012 | 03:38 PM
nope pushed the lever very hard it clicked and all is well .....thasnks for the help guys
Old Jun 26, 2012 | 06:55 AM
BLKPPR's Avatar
Good, that's what I thought. It feels like it's going to break
sparks
Dec 7, 2014 03:30 PM
JeffRB
Maserati
Jul 13, 2012 11:54 PM
steve harris
Sep 10, 2009 03:39 PM
steve harris
Feb 18, 2006 01:17 AM
