Car shaking after replacing brakes?? HELP
Old Oct 29, 2013 | 12:03 AM
trouble29's Avatar
trouble29 is infamous around these parts
Hello, I have a 06' Turbo, after replacing all brakes and rotors, the car started shaking hard at speeds of 60-70mph. On regular driving it doesn't shake only at high speeds. It was normal for about a month after instal, and now is shaking bad. What can this be from??? Please help
Old Oct 29, 2013 | 08:48 AM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
Best guess, would be either you have or need hub centric rings? Are these aftermarket wheels?
Or you did not install the rotor set screw tightly enough. Did you buy new rotor set screws?
Old Oct 29, 2013 | 09:29 AM
mx22's Avatar
mx22 is infamous around these parts
Given it was fine for a month after you replaced brakes... Did you hit a pothole or swapped tires without balancing them on the wheels? I once had a set of wheels/tires that my mechanic for some reason could not properly balance and he warned me that I might experience vibrations over 60mph.
Old Oct 29, 2013 | 04:53 PM
trouble29's Avatar
I have stock 20" wheels on the vehicle. I dont know if the mechanic used new bolts or not. As far as any potholes, I dont recall any but its possible but nothing happens while Im driving at that speed, only vibrates when I brake, how would the wheels have anything to do with that?
Old Oct 29, 2013 | 05:51 PM
mx22's Avatar
Well in your original message you only say that car vibrates at high speeds, you did not mention that car vibrates only when you brake. Warped rotors perhaps?
Old Oct 29, 2013 | 07:56 PM
trouble29's Avatar
Is it possible they can get warped after a month of install? And how would I check just run my finger over it?
Old Oct 29, 2013 | 09:35 PM
mx22's Avatar
Check this link:
http://www.tirerack.com/FAQ/results....ory=Brakes#141
I could be wrong about warped rotor, at least going by the description provided in the link above, it is not it.
Personally I would take the car to a mechanic and have the brake system completely checked. It can't get much worse then finding yourself on the highway with non working brakes...
Old Oct 29, 2013 | 10:54 PM
trouble29's Avatar
any good known mechanics in the los angeles area??
Old Oct 30, 2013 | 06:58 AM
XR4Tim's Avatar
XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !XR4Tim Is a GOD !
Sounds like one or more tires out of balance. You may have lost a wheel weight.
Old Oct 30, 2013 | 01:20 PM
mtnrat's Avatar
mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !mtnrat Is a GOD !
That's what I was thinking. Go for a balance first.
Old Oct 30, 2013 | 01:21 PM
Moderator
The rotor set screw is on there to make sure the rotor stays flush after the wheel hub. If the rotor set screw was not reinstalled or loose, it would cause the rotor to wobble on braking. Ask me how I know...
2lflat4
Nov 18, 2019 05:05 PM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
