AC not working?
Old May 26, 2014 | 12:22 AM
stormy69's Avatar
stormy69 is infamous around these parts
AC not working? update with durametric info
I have been out of town for three months and took the cayenne (06 tts w 4 zone climate control) out for a drive today and the ac is not getting cool (cabin fans and controls all seem normal). Checked system pressure, its good. checked s11 fuse also good.
no fault lights... i have a durametric setup but haven't used it yet and have too much going on right now to devote a lot of time to this. I need a/c lol. Any thoughts appreciated.
Old Jun 6, 2014 | 07:30 PM
YBE's Avatar
YBE
YBE is infamous around these parts
I feel your pain man It gets hot pretty quick in the 955 without A/C too with all that leather mine says the ambient air sensor is faulty how ever it still blows cold, might want to check yours..
Old Jun 8, 2014 | 12:29 AM
stormy69's Avatar
Its true, should have time to use the durametric on it tomorrow...
Old Jul 18, 2014 | 04:19 AM
stormy69's Avatar
Car (06 CTTS) was dormant for 3 months when i went out of town for "2 weeks"...
upon return, i charged the battery but have no functioning a/c (4 zone)
I hooked up the durametric today and was given the following;
1592, air quality sensor
565, a/c regulator control module no signal/communication
I ran the self test. it was vague as to any results on the durametric, but all doors and fans appeared to function correctly. I cleared the codes, still no go.
ran through the service manual, running out of time i skipped a little and it basically is telling me that the rear control module may be faulty.
I need part numbers for both (i couldn't find either on pelican or sunset) and is the module a common issue/repairable? what about the a/q sensor?
its too hot to drive the pig without a/c
TIA!
Old Jul 19, 2014 | 12:16 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
The AC system has been broken for at least 7 weeks, and you haven't taken it to the this shop and left it to be diagnosed and/or repaired? I guess the alternative is put the windows down and drive.
Old Jul 19, 2014 | 02:03 AM
stormy69's Avatar
yes, but i have alternative means of transportation. I normally only use the cayenne for long trips with more than one passenger. I haven't had time to mess with it, and haven't needed it. I have no intention of taking it to anyone...
i did put my tester on the battery today, after a full trickle cycle, it only shows 448 cca so will be getting a new one.
I need to perform the pinout tests in the service manual for the control unit after that.
Old Jul 20, 2014 | 01:06 PM
stormy69's Avatar
new battery and cleared codes, no change. pinout test is on the agenda for today...
Old Jul 20, 2014 | 01:58 PM
tex94's Avatar
tex94 is infamous around these parts
I had a similar issue one time with my cayenne. We drove for like an hour hoping it would start to cool down. I was able to get it working again by playing around with the AC controls on both the passenger and driver side. Sorry, I don't remember the exact sequence or know exactly what did the trick. But somehow it started working and I have had zero issues. What I think happened is that somehow the driver and passenger side climate control got out of sync and I was able to eventually reset it - so more of a computer issue than anything else. YMMV. Good luck
cinellipro
Dec 20, 2017 07:12 PM
alwaysbored786
Apr 19, 2016 05:51 AM
riverflyer
Sep 1, 2015 04:22 PM
Aug 21, 2015 06:34 AM
