**HELP!!** Climate control stopped working!
Old Sep 5, 2014 | 09:49 AM
Rampino's Avatar
Rampino is infamous around these parts
Exclamation **HELP!!** Climate control stopped working!
2004 CTT
Hi all,
I was checking to see if my antenna cables were plugged into my PCM because I am not picking up satellites and my reception is bad (worse than other Cayennes). I put the radio back in and now my climate control will not power up??
I had pulled some fuses to check if they were good and did replace one blown 20a fuse while I had the radio out. (#5 on the drivers side; auxiliary power I think).
I think this is the first problem that I have not found any information on while searching.
Any help or input will be appreciated.
Thanks,
Mike
Old Sep 8, 2014 | 02:09 PM
Renaissance.Man's Avatar
Moderator
Renaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond reputeRenaissance.Man has a reputation beyond repute
The wiring harness do not have much slack in that area. The most obvious is to try to put your hand back behind the climate control and try to reinsert any connectors that might be loose. Have you tried this?
Old Sep 8, 2014 | 03:54 PM
Rampino's Avatar
I actually pulled the whole climate control module out and checked the plugs. All 3 where firmly planted. I am still looking for the fuse for the climate control. I am surprised that there is not a separate fuse listed for it.
Old Sep 8, 2014 | 09:23 PM
Moderator
I agree. I took a look at a MY05 Cayenne Turbo owners manual and highlighted all fuses that look like they may be related. Please check these (below) and let me know what you find.
cinellipro
Dec 20, 2017 07:12 PM
Glasig
Aug 23, 2015 03:35 PM
saline
Aug 19, 2015 12:25 PM
