2009 Cayenne S starting problem
Old Mar 11, 2020 | 12:07 PM
andrewpepper09's Avatar
andrewpepper09 is infamous around these parts
Hi all,
New here...thanks for having me on your site!
I have a 2009 Cayenne S 4.8 that has an intermittent starting issue. Battery has been replaced so I know this isn't the problem.
Cold starts seem fine, though a bit more laboured than I would like, it's starts when the engine is warm that are a problem.
If I let it cool down for a few mins and try to start it back up it doesn't seem to crank as quickly and then the cranking will stop and I will have to try again. If I try right away it was crank maybe once and stop and I will need to try again.
The fact that I have no issues when cold tells me that it could be a starter on the way out? But given my symptoms before I proceed with a 4+ hour job and expensive new starter I was wondering if there is anything else I should look for first?
Thanks in advance!
Andrew
Old Jun 22, 2020 | 11:27 AM
redzero's Avatar
Registered PM
redzero is infamous around these parts
Originally Posted by andrewpepper09
Hi all,
Thanks in advance!
Andrew
new starter should solve the problem
Old Jun 27, 2020 | 02:12 PM
richie996's Avatar
richie996 is infamous around these partsrichie996 is infamous around these parts
I have an 09 as well at around 90k miles, my thermostat went so I had the starter & water pump replaced as preventative maintenance. The starters seem to go around 100k and the symptoms you describe are exactly what people stated happens before it fully bites the dust.
Phoenix0917
Cayenne 955/957
Sep 25, 2018 12:44 PM
TGED
Cayenne 958
34
Mar 14, 2017 06:59 PM
cayou31
Cayenne
Jun 7, 2014 07:18 AM
bapo
Cayenne 955/957
10
Jan 9, 2011 03:33 PM
RacerX
Cayenne 955/957
Nov 29, 2004 08:32 PM
