Cayenne will not stay running. New battery installed.
Old Dec 9, 2024 | 08:38 AM
RickKlem911's Avatar
RickKlem911
2013 Base Cayenne 3.6 L
I had a CEL so I plugged in my D7 scanner. There were codes about KAM . So I figured that it was a bad battery considering that it had the original battery from 2013 and this is 2024. Wow 11 year old battery.
I don't know why I did the next step but I did. I started the engine, and ran the scan again while it was running. After the scan was done I cleared the errors , while it was running. The engine misfires and stumbled a few times then finally shut off.
I figured the battery was bad so I replaced it with a DieHard same specs. But now when I crank it, It will run for 2 to 3 seconds and then shutoff. I can restart it and it does the same thing. I ran the scan for codes and it has no codes logged.
What is going on here? If I screwed up the settings hiw can I get them back to factory default? I did have the battery disconnected for about 3 hours while I went to get a new battery.
I am stressing and I need help
Rick
scrinja
Bentley
Dec 12, 2024 08:28 PM
Antigravity Batteries
May 2, 2019 12:19 PM
Apr 1, 2019 12:09 PM
gr8ful
Cayenne 955/957
Mar 11, 2011 02:18 AM
