From 0-300 km/h (186 mph) in just 10 seconds!
Didn't know where to put this, its COMING SOON, so GET READY TO GET YOUR HEADS BLOWN OFF.... Warning: Not for the faint hearted
2006 Weineck Cobra 780 cui Limited Edition
Story:
Bad Gandersheim, Germany, is the home of Weineck Engineering, manufacturer of the world's most powerful, strongest and best accelerating road - legal car. Highly visible: The gigantic airscoop of the engine bonnet is really a necessity since it and the engine bonnet cover V8 with a cylinder capacity of 780 cui (or 12.9L).
The first turn of the key activates a gigantic high-pressure fuel pump. To tromp and release the accelerator pedal means more than half a litre of finest nutrition (fuel) have arrived inside the ultra high-performance carburetor system to feed the devil, that is Weineck's custom milled V8 engine. The next turn activates the gigantic starter motor to spin the crankshaft resulting in an latent idle of 1,000rpm.
Even up to 4,000 rpm, the Weineck Cobra 780 cui Limited Edition accelerates faster than any other supercar when fully driven. The accelerator pedal always has to be operated very gently and with respect. The world's most powerful, strongest & best accelerating road-legal car and its absent of aids from the digital era like ASR, ESP, ABS etc.
Above 5,000rpm the engine delivers its world record torque of 1300 ft.lbs (1,760 Nm) at 5,600rpm. It's more like Sol 5 on Starship Enterprise! The rev. limiter is set to cut in at 8,000 rpm and the engine reaches its maximum power of 1,100 hp at 7,000 rpm. Infact, the engine revs faster than the classic Smith instrumentation can follow!
From 0-300 km/h (186 mph) in just 10 seconds! That is, of course, not only possible by using the strongest, naturally aspirated engine ever built for a road car.
Power is nothing without control! That's why the Weineck Cobra 780 cui Limited Edition is being built using a MIG welded, self-supporting tubular frame with a 4inch diameter to absorb very high torsion forces created by the engine. Additionally, its body is deep drawn from carbon composite materials for maximum rigidity.
Single wheel suspension including a continuously variable coil spring system in conjunction with a specially engineered Brembro brake system guarantees an individual set-up suiting individual driver's preferences resulting in high-precision driving and braking.
The 4-speed extra high-performance gearbox, driveshafts and rear axle (equipped with a 75% limited slip differential) are designed for more than 2,000Nm of torque!
The interior of the Weineck Cobra 780 cui Limited Edition will be designed individually to meet any customer's wishes. Normally, finest British leather is being used for the upholstery of the seats. All colours, pipings and sewings can be individually chosen. The rest of the passenger compartment is finished by using velours carpets. For the dashboard, classic Smith instruments are being used.
In case of rain, the car is equipped with a soft top to protect both the driver and the interior. If requested, a fixed hardtop is also available.
Each unit of the Weineck Cobra 780 cui Limited Edition is a unique masterpiece of German Engineering. Only 15 lucky individuals worldwide will be able to share the experince of 780 cui!
Story by Weineck Motorenbau
Performance Figures:
Engine: All Aluminum Donovan V8 w/Weineck Pistons, Crank, Heads
Aspiration: Natural
How the....????
Displacement: 12782 cc / 780 cu in
Power: 820.3 kw / 1100 bhp @ 7000 rpm
HP Per litre: 86.06 bhp per litre
Torque: 1760 nm / 1298.1 ft lbs @ 5600 rpm
Transmission: 4-Speed Manual
Body/ Frame: Carbon-Composite Body over 4 Inch Steel Ladder Frame
0-300 Kph: 10 seconds
Story:
Aspiration: Natural
How the....????Displacement: 12782 cc / 780 cu in
Ya that thing is nuts hey? Can anyone here say "traction issues"?
How in hell do you transfer 1300lbs of torque through two street tires in a car that weighs 990kg with a 780CI engine OVER THE FRONT WHEELS?????
1100hp/1300lbs - 990kg - no Traction Control/ABS/etc = one death machine holy crap.
If you sneeze while driving this car the variation in throttle position transmitted by you foot will land you in the ditch.
I'm sure its rediculously fast, but I don't have much respect for a car that looks to be basically a kit car constructed with expensive materials and then powered by the biggest freakin engine they could fit (that only gets a pathetic 86hp/L).
As a dragster maybe its OK, but as a supercar the engineering that went into the Bugatti Veyron to make it fast AND usable takes it for me any day of the week.
Edit: I just noticed the 427 badge on the front fender!!! LOL!!
Hmmm... The power and/or torque figure must be wrong. Possibly the wrong way round. 1298lbft @ 5600rpm is almost 1400bhp already, i.e. more than 1100bhp. Also, 101lbft/L is a heck of a lot for an NA 12.9.
