wheel well cleaning question
Old Mar 17, 2008 | 04:26 PM
jkb's Avatar
jkb
jkb is infamous around these parts
so i read this wonderful write up but still have one question. what do i use for the plastic wheel well liner to bring out the black? is that "black wow"?
thanks
Old Mar 17, 2008 | 08:22 PM
MoeMistry's Avatar
Premium Sponsor
thanks
einszett vinyl rubber care works for me.
Old Mar 18, 2008 | 12:25 PM
Stealth 993's Avatar
Stealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond repute
You don't really want much shine in there, just a matt clean look.
I use undercarriage spray, Detailers Domain, & other sell it.
If you are going to show the car, if the wheels & under side are "shinny" you will loose points.
Old Mar 21, 2008 | 08:48 AM
MoeMistry's Avatar
Premium Sponsor
the einszett vinyl rubber can be matted if wiped off after a few minutes. I like using it because the spray trigger gives an even fine mist; no other sprayer has done that for me.
Old Mar 21, 2008 | 10:46 AM
Moe, throw out the included spray bottles, & purchase by the gallon. Then pick up the high quality adjustable sprayers. You will same a ton of time, on pulling the trigger & get a finer more powerful mist!
US Plastics has great bottles & sprayers for like $2-4 a unit.
Old Mar 22, 2008 | 01:23 PM
Linko4's Avatar
Linko4 has a spectacular aura aboutLinko4 has a spectacular aura aboutLinko4 has a spectacular aura about
Interesting... that link shows great results on the car.
Old Mar 23, 2008 | 06:31 PM
Oxygen's Avatar
Oxygen is infamous around these parts
Here are the results in on my car....
Basically the guy suggests cleaning all the salt, sand and other **** out of your wheel wells before you put on your summer wheels...
So here is my attempt with details...
What you will need:
Jack
Brake Parts Cleaner
Engine Degreaser
Car Wash Concentrate
Sand Paper
Hard Bristle Rim Brush
Rags and Towels
How much time will you need:
1.5 to 2 hours
What I used:
Mothers Back-to-Black
Meguiar's NXT Car Wash
Advance Wheel & Tire Cleaner
GUNK Engine Brite
CRC Brakleen Brake Parts Cleaner
Dupli-Color Silver Coating
RUST-OLEUM Satin Black Spray Paint
Meguiar's Ultimate Quick Detailer
*** POWER WASHER RECOMMENDED!
Remove the wheel, spray the area with water and then with a rag or car cleaning mitt clean the whole area including the shock, control arms, etc with the car was solution. Wash the soap away with water and spray only the wheel well with wheel and tire cleaner. Clean it with a rag, wash it off. If there is a lot of grease, you might want to give it a wash with the engine degreaser also. I sanded all the rust off of my hubs. If the plastic is old and dry, you will want to give it a very LIGHT coat of the Back-to-Black stuff.
I also cleaned the inside and outside of the rims thoroughly while they were off the car.
...and I also painted my nasty rusty lug nuts while I was cleaning each one of the wheel wells...
Now to the pictures...
BEFORE
AFTER
BEFORE
AFTER
AFTER
BEFORE
AFTER
Old Mar 23, 2008 | 07:07 PM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
pretty good results.
Aug 21, 2015 09:56 AM
roncooper
Aug 19, 2015 01:17 PM
Wheel Experts
American Muscle
Aug 19, 2015 09:07 AM
Wheel Experts
Wheels/Tires
Aug 19, 2015 09:05 AM
