How about this scratch - help, please!
Old Jun 24, 2008 | 11:13 PM
cellg8's Avatar
cellg8 is infamous around these parts
Don't want to high-jack the other thread... so here's the scratch I found today on top of the fender of our Cayenne. Anyone know what might have caused this (I think someone keyed it). So I washed, polished with Menzerna SIP, 106FF, then put on Glanz Wax...but it still shows (not as white and you can see from a certain angle)...
My question is....will it get rusted? What do I need to do now? How do I fill this scratch?
Thank you...
Old Jun 24, 2008 | 11:21 PM
Grouse's Avatar
Grouse is infamous around these parts
Hmm,
John, it looks like it is probably through the clear. you could try and layer color in there, do a full repaint of the fender, or have it spot resprayed.
Old Jun 24, 2008 | 11:50 PM
Zaks's Avatar
Zaks is infamous around these partsZaks is infamous around these parts
It's hard to tell too much from the photo, but it sure does look big enough to be through the clearcoat... it won't rust unless it's down to the metal
When you say it can still be seen, are you talking about just an indentation or an actual white-looking scratch? If it's an indentation, it was most likely not all the way through the clear and you fixed it a bit with the polishing. If it's still white it might be very deep (I can't see if it's metal or not but since you said it's barely visible I'm assuming it's not that deep).
If it still bothers you, I would suggest trying a light wet sanding, with 3000 or 4000 grit, then polish again with SIP and 106ff... if it doesn't bother you, just make sure there's no metal showing and you're good to go... I would still keep it sealed though as over time (although this would take pretty long) there could be some UV damage done if cc is missing in the spot... like I said, that's a small piece of cc missing (if it is in fact missing) so the cc damage from UV would take years and years... even then it's just a fender, quick re-spray and you're done haha
Old Jun 25, 2008 | 08:03 AM
cellg8's Avatar
Thank you, gentlemen! Lecchilo, it's not really white anymore..just a deep scratch.
How do I seal it? Just apply wax?
Old Jun 25, 2008 | 10:11 AM
Zaks's Avatar
Yea, wax or sealant... I had a 1"x1" chip on my hood before that was bare metal, and Klasse Sealant Glaze kept it from rusting even a bit for a good 6-7 months, before I filled it in (badly might I add haha)
Old Jun 25, 2008 | 06:32 PM
Stealth 993's Avatar
Stealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond reputeStealth 993 has a reputation beyond repute
It looks like a shopping cart, or some other metal object on a person, like a key chain, or something dangling from a purse.
Can you feel it with your finger tip? You might have to add some touch up paint. It should not rust, unless it's down to the bare metal.
Old Jun 26, 2008 | 02:45 AM
Linko4's Avatar
Linko4 has a spectacular aura aboutLinko4 has a spectacular aura aboutLinko4 has a spectacular aura about
I think that scratch is done deeo, you might have to repainted. You can try polish it, but I doubt that it will work because it's deep through clear.
Old Jun 26, 2008 | 07:10 AM
cellg8's Avatar
Thank you all for the replies, gentlemen... Yes, I can feel it with my finger tip. Hopefully it won't cost too much to get that fixed one day...
Old Jun 28, 2008 | 10:08 AM
Gloss-it's Avatar
Gloss-it is infamous around these parts
Thank you...
Wow! It looks pretty deep, ouch. Question can you use a finger and tell me if you catch an edge? If so then looks like a repaint. But if its only deep in a few area's along the scratch could try to block with 1500 or 2000 grit wet sand paper then follow with a mild cutting polish. Let me know and we can go from there.
Old Jun 28, 2008 | 11:11 AM
Zaks's Avatar
Gloss it, did Moe design your avatar?
Old Jun 28, 2008 | 11:26 AM
Gloss-it's Avatar
Nope he copied it! He just wish he had my looks!
Old Jun 28, 2008 | 11:34 AM
Zaks's Avatar
Sorry but I like Moe's better... he's showing some skin with the shorts
Old Jun 28, 2008 | 12:43 PM
Gloss-it's Avatar
Beauty is in the eye of the beholder!!
TOGWT
Detailing
Oct 1, 2015 07:59 AM
TOGWT
Detailing
Sep 27, 2015 06:09 AM
