1500 sc's
Old Oct 29, 2009 | 01:49 PM
solekeeper's Avatar
solekeeper is infamous around these parts
1500 sc's
I'm curious as to what you guys think would be best for cutting 1500 sand scratches.
-Currently using 3m's Perfect it 3k I beleive (Forgot the full name)
I would like to switch because it dusts way too much, and is a hassle to clean up.
-Also, it tends to leave alot of micro-marring.
Can anyone recommend me something that can cut the equivalent to the 3m?
A pad to go along with the compound would also be great.
I ran across this, and these scratches loook TERRIBLE, and if the Mpo85 can handle this, with those kind of results, I think it could handle the 1500?
Thanks alot guys!
http://www.detailersdomain.com/menze...ishpo85rd.aspx
Old Oct 30, 2009 | 06:59 PM
Detailed Image's Avatar
Detailed Image is infamous around these partsDetailed Image is infamous around these parts
A nice option to cut through 1500 grit sanding marks is Meguiar's M105 using orange pads. It's a great polish that is versatile and can offer a lot of correction on almost any paint. You could follow up with M205 using white pads, then the PO85RD on black if desired. Here's a step-by-step tutorial on the M105 / M205 polishes by a top professional detailer.
PO85RD offers very little correction ability and wouldn't put a dent in any wet sanding marks.
Hope this helps.
Old Oct 30, 2009 | 08:36 PM
solekeeper's Avatar
I think you just sold me on that product.
Will be buying tomorrow most likely, along with the pad.
Another quick question, after using my 3M at the shop, I follow up with 3M's ultrafina on their blue pad and have had great results even on black. I mean absolutely fantastic.
Now, i'm assuming since the m105 appears to finish better then the 3M perfect it, I should have no problem going from the M105 to my Ultrafina right??
Thanks man!
Old Oct 30, 2009 | 08:56 PM
detailjohn's Avatar
detailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to beholddetailjohn is a splendid one to behold
Do you have the Perfect it 3000 Extra duty rubbing compound? If so, you have most of what you need, but I personally prefer either Menzerna Power Gloss, or Matrix polish I. To rub out 1500 grit sanding scratches, I recommend compounding with a wool pad. Compounding will leave a lot of heavy swirling, you would then go to a orange pad with Menzerna SIP, or Matrix II, then finish with Menzerna Super Finish, or Matrix III. I would stay away from most of the Perfect It line if possible, I think the only quality one they sell is the Ultrafina.
John
Thanks alot guys!
Old Oct 30, 2009 | 09:14 PM
solekeeper's Avatar
How much is a bottle of Menzerna Power Gloss?
And how does it compare to the finish of the M105?
This is the Power Finish correct?
http://www.detailersdomain.com/menze...ds34a16oz.aspx
Old Oct 30, 2009 | 10:49 PM
detailjohn's Avatar
Both Moe at www.glisteningperfection.com and Phil at www.detailersdomain.com are both site sponsors, and both carry this product.
John
Old Oct 31, 2009 | 08:01 AM
solekeeper's Avatar
Do you have any input on the M105?^
Old Oct 31, 2009 | 08:56 AM
MoeMistry's Avatar
Premium Sponsor
Originally Posted by detailjohn
do you have the perfect it 3000 extra duty rubbing compound? If so, you have most of what you need, but i personally prefer either menzerna power gloss, or matrix polish i. To rub out 1500 grit sanding scratches, i recommend compounding with a wool pad. Compounding will leave a lot of heavy swirling, you would then go to a orange pad with menzerna sip, or matrix ii, then finish with menzerna super finish, or matrix iii. I would stay away from most of the perfect it line if possible, i think the only quality one they sell is the ultrafina.
John
+1...
Old Oct 31, 2009 | 08:57 AM
MoeMistry's Avatar
Premium Sponsor
Thanks alot guys!
I just replied to your PM...we also have the purple wool pad, just place your order and I'll throw one in at no charge...you'll love it.
porschetech
Aug 6, 2016 03:00 PM
freddiemac
Oct 7, 2015 11:05 AM
bpanos
Sep 24, 2015 03:53 PM
