Brake dust cleaner
Old May 9, 2010 | 03:37 PM
solrac6262's Avatar
solrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to all
Brake dust cleaner
what u guys recommend when you have brake dust like this on your wheels?
Old May 9, 2010 | 05:50 PM
Dan1's Avatar
Dan1 has a spectacular aura aboutDan1 has a spectacular aura aboutDan1 has a spectacular aura about
What have you tried so far?
Old May 9, 2010 | 06:50 PM
solrac6262's Avatar
on normal circumstances p21s cleaner gel, but last time that I received a set of wheels really dirty I had to use acetone.. and don't think thats safe for the wheels, but even usign aceton it was super hard to get the brake dust off the wheel.. so this time I will like some help from the pro's..
Old May 9, 2010 | 08:35 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
If you're referring to the dark brown/tan on the inner edge, that looks more like the cosmoline protectant applied to new cars. That will take something most likely stronger than brake dust cleaner, but I'll let the pros tell you what is safe to use, there are several things that will take it off, along with more.
Old May 9, 2010 | 08:53 PM
solrac6262's Avatar
didn't think of cosmoline, maybe some simple green... I'll try that tomorrow..
Old May 10, 2010 | 08:06 AM
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
If you have access to one of those hand held steamers, you might try that just to break up the caked-on dust. I had to use that on the stock wheels on my 560SL that had not seen any attention in the 20 years prior to me owning it. I had tried most every cleaner including Simple Green, but it took the steam to break up the crust that had formed. Your's don't look nearly that bad, but a shot of steam might help get rid of what you've got there.
Old May 10, 2010 | 08:12 AM
solrac6262's Avatar
thanks I will try that first
Old May 17, 2010 | 05:31 PM
PORSCHEFREAK's Avatar
PORSCHEFREAK has a spectacular aura aboutPORSCHEFREAK has a spectacular aura aboutPORSCHEFREAK has a spectacular aura about
Try a wax or silicone remover. I had the same problem before till I found this new product and it worked wonders.
Old May 17, 2010 | 07:33 PM
MoeMistry's Avatar
Premium Sponsor
Great eye...that's cosmoline. Something like P21S Total Auto Wash or 3M General Purpose Cleaner will do the trick. Great question OP.
http://www.glisteningperfectionstore...to-wash/Detail
http://www.glisteningperfectionstore...dhesive/Detail
Old May 17, 2010 | 09:38 PM
99C2's Avatar
99C2 is infamous around these parts
solrac:
Yep you need to get that coating off the rim and put some good wax on (should remove the wheel) and use the spray detailer on a semi disposable MF towel and they will always remain clean.
I clean mine at least once a week. But my cars are weekend only rides.
99C2
ModBargains
Oct 13, 2015 03:40 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
