road debris kicking up fender well
Old Jan 1, 2011 | 02:40 PM
solrac6262's Avatar
solrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to allsolrac6262 is a name known to all
Have any of you had problems on 997's with paint damage on the painted arch wheel area in front of rear tires , fender well due to road debris kicked up by the tires similar to sand-blasting the paint?
Old Jan 1, 2011 | 03:42 PM
xXxGhotimanxXx's Avatar
xXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond reputexXxGhotimanxXx has a reputation beyond repute
Yep. Although I wouldn't call it a problem...I'd call it painted area behind wheel gets chipped from driving. Only solution is mud flaps...I'll take the chips .
J
Old Jan 1, 2011 | 04:34 PM
solrac6262's Avatar
how about the side rockers? do you get that problem also
Old Jan 1, 2011 | 05:51 PM
MoeMistry's Avatar
Premium Sponsor
Those areas are very common if you drive your car. Best thing is to protect it with clear film before it gets worse, or, repaint, and put clear film on.
Old Jan 1, 2011 | 05:59 PM
solrac6262's Avatar
thanks Moe, can it be repainted just the edge of the wheel? also do you think this yellowish color is from the clear coat Moe?
Old Jan 1, 2011 | 06:02 PM
MoeMistry's Avatar
Premium Sponsor
That textured area is not usually clear filmed because of the inconsistent texture. You can however repaint that general area. I've never seen it turn yellow like that before. Have you applied any products to that area?
Old Jan 1, 2011 | 06:05 PM
solrac6262's Avatar
no nothing at all, I noticed it was repainted, maybe it had some road chips.. but don't know why it looks like that, I don't think some clay and polish can help, but just afraid to try
Old Jan 1, 2011 | 06:13 PM
MoeMistry's Avatar
Premium Sponsor
If it's repainted, then it wasn't done correctly. It looks like clear coat failure. Did you have it repainted? If so, take it back and have them redo it.
Old Jan 1, 2011 | 06:20 PM
solrac6262's Avatar
No I didn't, probably dealer did it for touch up purposes, but sometimes they do pretty S#@# job's too, but I noticed this today.. I might ask them if they did the spray and see if they can fix it, if not I'll wait and if takes my sleep I'll have a shop fix it thanks for the help Moe
spitfun
May 7, 2020 08:00 AM
Texas1
Sep 20, 2015 09:12 AM
sechsgang
Sep 18, 2015 09:27 AM
alwaysnboost
10
Sep 9, 2015 11:36 AM
