tint removal ?
Old Oct 7, 2013 | 11:54 AM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
tint removal ?
any experience on tint removal? Heat gun or steamer seems to be best ideas? Links and which is the better method?
Old Oct 8, 2013 | 08:51 AM
MoeMistry's Avatar
Premium Sponsor
One advice...leave it to the pros. A lot can go wrong and a good shop doesn't charge a whole lot to remove it.
Old Nov 1, 2013 | 06:35 PM
last mango's Avatar
last mango is infamous around these parts
Easy!
I found a you tube video of a guy using a steamer and duplicated what he did. A second set of hands is important, and don't force it, let the steamer do the work. It was easy, glad I did it!
Old Nov 2, 2013 | 08:55 AM
cerbomark's Avatar
I did it using a heat gun. You are right, you cant pull it too soon.. Not a bog deal but a little messy... thanks, mark
Old Nov 28, 2013 | 12:41 AM
carrera997re's Avatar
carrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant futurecarrera997re has a brilliant future
Bumping a old thread but im debating about removing my tint anyone have any problems with the rear window? The defroster strips make me nervous
Old Nov 28, 2013 | 04:31 AM
cerbomark's Avatar
I d use a wallpaper steamer if I was going to do rear window. Side are not that hard at all.
Old Nov 28, 2013 | 05:07 PM
last mango's Avatar
Steamer
I just used a travel steamer for clothing and it was fine on the rear window, not a lot of heat just a lot of moisture. Just pull it steady and slow or you will leave some glue on the window.
Old Nov 28, 2013 | 09:30 PM
neos281's Avatar
neos281 has a spectacular aura aboutneos281 has a spectacular aura about
Same here. I used my trusty clothing steamer. There was a little glue left behind on the rear window and for that I used a little windex. The ammonia practically dissolved whatever was remaining.
Steamer is the best method, IMO.
Old Nov 29, 2013 | 05:14 PM
mto's Avatar
mto
mto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud ofmto has much to be proud of
Agree about Steamer, I pulled on a 45 degree angle and it helped avoiding flaking off small pieces. Mine was on for 15 years.
Old Nov 29, 2013 | 05:16 PM
Thanks guys.
NIKAS
Aug 20, 2019 07:53 PM
markj
911
Apr 7, 2016 05:44 PM
