Carpet Cleaning and Care
Old Oct 8, 2015 | 06:00 AM
TOGWT's Avatar
TOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to beholdTOGWT is a splendid one to behold
http://togwt1980.blogspot.co.uk/2015...-and-care.html
An extractor is used for the deep cleaning of carpets; it forces hot water and detergent deep into the fibres and then draws it out with a powerful vacuum.
The advantage of foam over liquid is the minimum amount of moisture, very important for cleaning absorbent and moisture sensitive materials. Use foam cleaner, which should be given dwell time and then gentle agitation with a medium stiff bristled brush to get the product into the materials surface, the low moisture content of foam can then be easily rinsed and the surface dried.
When using a vacuum or water extractor always allow the machine to do the work, there is absolutely no need to scrub with the nozzle, or use downward pressure as this will greatly restrict airflow / suction. Instead place the nozzle on to the carpet or upholstery so that it makes contact lightly, this will introduce vacuum deep into the fibres and bring the particulates and soil to the surface for easy pickup by the vacuum.
DetomasoGTS74
Nov 11, 2015 09:01 AM
spinecho
Sep 6, 2015 08:35 PM
jmorgan911
Aug 28, 2015 10:24 AM
nal991
Aug 24, 2015 04:39 PM
