Porsche 996TT Stg 4 Detail
Old Apr 4, 2007 | 01:17 AM
detailersdomain's Avatar
detailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond reputedetailersdomain has a reputation beyond repute
2002 Porsche 996TT Stage 4 Silver/Black
I got TonyNJ's P-car after he ran the Exotix Charity Run 07 (NY/NJ/CT). Amazing vehicle!
For the most part this car was pretty much prefect. Just dirty, needed some cleaning, claying, and a polish, and finally some wax.
As for the interior a wipe down and some leather feeding.
Products used:
Adam's Car Wash
Shmitt Wash mitt and Shmitt Wheel mitt
2 Buckets with grit guard
Jumbo Waffle Weave Drying Towel
Microfiber Buffing Towels
Boar's Hair Brush
Spoke brush for the inner wheels
Adam's VRT
Adam's Glass Cleaner
Adam's Detail Spray
Adam's Clay Bar
Adam's Metal 2
Menzerna 106FF/Nano
Phil's Secret Wax... [] (I have 2 actually, one that is about 25-29% Carnauba content in paste form (which you can apply with an applicator) and the other about 41-49% Carnauba content (this one is similar to the Zymol Vintage which you have to apply with the warmth of your hands. Its just to hard to handle with an applicator pad)
P21S Wheel Cleaner Gel
P21S Autowash
Metabo (hi speed rotary)
Firehose Nozzle
Edge Pads Dual sides (6 inch) white
Edge Pads 2000 (4 inch) green
1Z Einszett Leather conditioner/cleaner
1Z Einszett Detail Spray
Procedure:
1. Rinsed down the wheels (they were cool)
2. Sprayed down the wheels with some P21S Wheel Cleaner
3. Brush and cleaned the wheels with a Boar's Hair Brush
4. Rinsed down the wheels
5. Clayed the wheels (just the face/center, not a full wheel detail)
5. Rinsed down the car
6. Filled the buckets up with Adam's Car Wash
7. A great trick I use is to squeeze some Adam's car wash on the Shmitt giving it more suds as you clean. Going from top to bottom I typically go clean the roof then go to the bucket and rinse the Shmitt hitting the grit guard to make sure its clean for the next section (repeat this till the car is done) do this more frequently as you get to the bottom of the car and the back of the trunk/rear bumper.
8. Rinse car off throughly
9. Since there was no sun out and it was cool, I sprayed Adam's Detail Spray on the panels and proceeded to clay the car (Adam's Clay Bar) after each panel and each window was clayed I used the WW Drying Towel to wipe the excess detail spray off.
10. Car is clayed and dried.
11. Got out the Metabo with the white pad and Menzerna 106 and started with the rear spoiler (speed was 700-1200 rpm) couple passes and that's all I needed to get it perfect!
12. Polished out the headlights and tail lights with the 106.
13. Proceed to finish up the car with the 4inch (green) and 6 inch pads (white side) with the Metabo (love this machine) The 4 inch pads gave me more control and precision on the tight spots. (fenders, vents, rear deck)
14. With a MF Towel I buffed off the Menzerna 106
16. Applied the Phil's secret wax to each panel and used a MF Towel with some 1Z Detail spray to wipe the excess off to a super wet/deep/shine....[]
17. Cleaned up the windows with Adam's Glass Cleaner (interior/exterior)
18. Dressed the tires with Adam's VRT (did one pass on the applicator and did a pass using the dry side... Tony prefers a matte finish)
19. Used Adam's Detail Spray to do a final wipe down on the wheels.
20. Used the 1Z Detail Spray for a final wipe down on the car.
21. Wiped down the door jambs
22. Wiped down the interior and used 1Z Leather Cleaner/Conditioner (applied with a MF Applicator pad 1 pass to apply the next pass on the dry side to wipe to a matte finish, no shine for Tony)
23. Used some Adam's Glass cleaner to wipe down the aluminum mats.
24. Adam's Metal Polish 2 on the tips
Before:
Some suds:
Afters outside:
Old Apr 4, 2007 | 01:18 AM
Before wheels:
After wheels:
Before Tips:
After Tips:
Before Interior:
After Interior:
These are the out right best pics of the day as the sun wasn't out at all today so the shots inside the garage were best. Take a look.
After inside:
Old Apr 4, 2007 | 01:19 AM
Enjoy! I certainly did [] [up]
Old Apr 4, 2007 | 01:22 AM
Alex's Avatar
Alex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant futureAlex has a brilliant future
Hell of a rejuvenation! That's the way a P-car should look.
Nice job!
Old Apr 4, 2007 | 08:11 AM
TonyNJ's Avatar
TonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of lightTonyNJ is a glorious beacon of light
Phil is really amazing, my car is shining more than the day I bought it new. He is very professional, trustworthy, and really know's his product's. Thank's again and let's get started on the Denali soon.
Old Apr 4, 2007 | 11:16 AM
str8blst's Avatar
str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !str8blst Is a GOD !
Nice Phil! I'm going to try your Secret Wax/Sauce this weekend!
Tony: your garage is amazing! Phil does a terrific job on black cars. My S4 turned out phenominal after his tender loving touch....
Old Apr 4, 2007 | 11:39 AM
NoRoom4Error's Avatar
NoRoom4Error has a brilliant futureNoRoom4Error has a brilliant futureNoRoom4Error has a brilliant futureNoRoom4Error has a brilliant futureNoRoom4Error has a brilliant futureNoRoom4Error has a brilliant futureNoRoom4Error has a brilliant futureNoRoom4Error has a brilliant futureNoRoom4Error has a brilliant futureNoRoom4Error has a brilliant futureNoRoom4Error has a brilliant future
Extremely nice! Looks like you got a nice garage too. Sooo which is faster to 60 mph - the mini F1 or the porsche?
Old Apr 4, 2007 | 11:53 AM
jox's Avatar
jox
jox has a reputation beyond reputejox has a reputation beyond reputejox has a reputation beyond reputejox has a reputation beyond reputejox has a reputation beyond reputejox has a reputation beyond reputejox has a reputation beyond reputejox has a reputation beyond reputejox has a reputation beyond reputejox has a reputation beyond reputejox has a reputation beyond repute
Beautiful job and b-e-a-utiful P-car!
Now go give the RS6 some love
Old Apr 4, 2007 | 01:56 PM
JoeyG's Avatar
JoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud ofJoeyG has much to be proud of
Love the glossy wheels. They look great! Nice detail work too, you should pat yourself on the back .
Old Apr 4, 2007 | 02:38 PM
Yes Tony's Garage is nice I was just there to detail his P-car.
The RS6 gets the love here you go:
https://www.6speedonline.com/forums/...ad.php?t=76424
Old Apr 4, 2007 | 03:04 PM
Origyns 973's Avatar
Origyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to behold
I got lucky enough to make his car look clean when I took pictures of it Saturday...
Rest of the pictures on the site, http://www.origyns.uni.cc
Old Apr 4, 2007 | 05:42 PM
TonyNJ's Avatar
Thanks for the compliment's, the mini F1 car is pretty cool, my kid's love it. It took me a while to finish the garage but overall I'm happy with the way it came out.
Old Apr 4, 2007 | 09:36 PM
cooperlee's Avatar
cooperlee is infamous around these parts
love your turbo TONY!!!!
My blk tt was filfy dirty filled with salt and all sort of **** after the run from Sunday. I only gave it a quick wash today...
Phil...pls pm me about possibly giving my tt some tender loving care. how long would a exterior take on my tt if i come out to jersey?
Thx
Sam
Old Apr 4, 2007 | 10:53 PM
TonyNJ's Avatar
Thanks Sam, but I gotta say that your TT looks crazy slammed like that especially rolling. Beautiful car man!!! Mine was all full of salt also.
Old Apr 5, 2007 | 01:22 PM
cooperlee, pm sent. I would say about 6 plus for the exterior I'm assuming your interior is mint.
