Battery Tender
Old Nov 2, 2010 | 01:58 PM
dksu's Avatar
dksu has a spectacular aura aboutdksu has a spectacular aura about
Battery Tender
IF i drive my f430 once every 2 weeks, do i still need to hook up the tender? If so, i'm just concerned my house will burn down
Old Nov 2, 2010 | 06:02 PM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
I have been using them since they came on the market and are very safe.
Old Nov 2, 2010 | 10:01 PM
dfwerdoc's Avatar
dfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud ofdfwerdoc has much to be proud of
yes you need one. put it on a ctek 7200 and your house won't burn down.
Old Nov 2, 2010 | 11:28 PM
dksu's Avatar
I have the oem one that came with the car. Where and how do I hook it up? thank you!
Old Nov 3, 2010 | 12:14 PM
Lee Willis's Avatar
Lee Willis is a jewel in the roughLee Willis is a jewel in the roughLee Willis is a jewel in the rough
Well, one came with my 430 and I plug it in every time the car will sit more than 3-4 days. One also came with the Aston I had before that and I used it the same way.
You may not need to use it if the car sits for a week or ten days at a time (that is the longest I'd dare leave it, though) but I am certain the battery will last longer if you use a good battery tender and never let it slowly trickle down as it does when left for a while.
Old Nov 3, 2010 | 01:11 PM
dksu's Avatar
Do you mind sharing where and how to plug the oem tender? There isn't an instruction manual with the kit. thanks
Old Nov 3, 2010 | 04:19 PM
dfwerdoc's Avatar
you can google it and im certain you'll find it. im also fairly sure your owners manual has the info on the eom charger connection in appendix; mine does. or you can post in the 430 section of ferrarichat and im sure someone will post pics. the oem cs charger plugs inside the front lugage compartment.
Old Nov 3, 2010 | 09:03 PM
seattle_s4's Avatar
seattle_s4 is infamous around these partsseattle_s4 is infamous around these parts
On the F430, look in the passenger footwell under the right side where the glovebox is next to the glovebox pull (the red string that opens the box). You plug the tender right up in there.
Old Nov 3, 2010 | 10:02 PM
dksu's Avatar
Thank you KFC
Old Nov 6, 2010 | 08:28 PM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
OEM works great...
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
WheelsupZR1
Oct 20, 2015 08:36 PM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
