F430 Window switches
Old Jan 29, 2020 | 10:49 AM
broncoupe's Avatar
broncoupe is infamous around these parts
Hi have an 2007 F430 RHD
It has a battery drain I realised the window switches where illuminated after the car was left for 30 mins plus
Did a bit of research and fellow owners have had trouble with door micro switches and the advice is disconnect 1 at a time
Did this and eventually found if you disconnect the passenger outer door handle micro switch all shuts down after 5 mins with a satisfying click
What i find confusing is if i check the micro switch with a meter it seems to work everytime you lift the door handle ?
Old Jul 26, 2022 | 05:07 PM
jsburkhart's Avatar
jsburkhart is infamous around these parts
Find the Fix?
I am having this same issue. Did you ever find the fix for it?
Old Jul 27, 2022 | 07:20 AM
broncoupe's Avatar
It was the micro switch by the handle in the door tested ok but was faulty replaced all good
BF951
Sep 2, 2019 10:19 AM
DanJackson
Aug 25, 2017 07:35 PM
faandba
Jul 13, 2013 01:04 AM
Miykl
Aug 30, 2006 05:14 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
