French cars Got a Bugatti? A Hispano Suiza or a Citroen Traction Avant? Here is your forum
AMS drives Bugatti Veyron - 402km/h 250 mph!
Old Sep 2, 2005 | 02:08 AM
Erik's Avatar
Erik has a spectacular aura aboutErik has a spectacular aura about
Arrow AMS drives Bugatti Veyron - 402km/h 250 mph!
AMS chief editor Bernd Ostmann has been the first mag tester that had the pleasure to ride 400+ in the EB 16.4 Bugatti Veyron at VW test course Ehra-Lessien...
some impressions what he said about that day...
the track has been kinda damp in the morning, kinda scary at 400km/h, so 111m/sec without crash barries like in Nardo, well not really, rear wing setup to 2テつー so 40 to 50kg downforce at rear axle engineers promise that thisテつエll be enough for a smooth ride even on wet pavement...
through the first corner with 220 easily - absolute brutal accelerating up to 300 within seconds a light left hand bend with 380 - looking into the rear mirror - just an enormous spray but just like they told the EB16.4 is a very smooth car to ride even at that speeds...
the sepcial Michelin tires are working just perfect, they were tested up to 500km/h and before a high speed run they require 3bar pressure - this is one of the points the driver has to go through with a check list and a second car key to unlock the high speed mode - here the two front diffusor flaps are closed, the rear wing selects 2テつー and the body is lowered to 6.5cm front and 7cm rear a sepecial system is monitoring everything and when only one parameter is not ok the car automatically switches to handling-mode...
the first run ended with "only" 380km/h - the car switched to handling because the exhaust temperatures reached critical 970テつーC - cooling down the car at 220 or 5000rpm in 4th gear...
the weather gets better, itテつエs much warmer now and engineers force the AMS team to "act" - next run 398km/h - this time itテつエs the driverテつエs fault as he has enabled the A/C on the previous cooling lap costing some km/h on that fast run - so again a cooling lap and then full concentration on the last run with nearly 400 the rpm showed 5800 in 7th gear, now it shows 6200rpm at a speed of 402km/h ...
braking is again a new experience 31.4m (!!!) from 100 to 0 with a 1950kg car...
on the other hand acceleration is also outstanding - measured 25m long black rubber from all four wheels after the standard sprint with launch-control - result: 2.5sec to 100 and 7.3 to 200 :shock:
on a side note - at 400 km/h the EB16.4 needs ONE liter fuel for ONE kilometer so they calculated every 12min a gas station on autobahn when driving 400
Old Sep 2, 2005 | 02:21 AM
FAT-911's Avatar
FAT-911 is infamous around these parts
OH MY GOD
Old Sep 2, 2005 | 03:46 AM
PorscheFanatic's Avatar
PorscheFanatic has a reputation beyond reputePorscheFanatic has a reputation beyond reputePorscheFanatic has a reputation beyond reputePorscheFanatic has a reputation beyond reputePorscheFanatic has a reputation beyond reputePorscheFanatic has a reputation beyond reputePorscheFanatic has a reputation beyond reputePorscheFanatic has a reputation beyond reputePorscheFanatic has a reputation beyond reputePorscheFanatic has a reputation beyond reputePorscheFanatic has a reputation beyond repute
You can't have ac on to go 400km/h?
Does every car manufacturer display their top speed with the ac turned off?
Old Sep 2, 2005 | 06:18 AM
vtgts300kw's Avatar
vtgts300kw is infamous around these parts
2.5 seconds 0-100
Old Sep 2, 2005 | 06:23 AM
gsc's Avatar
gsc
gsc has a brilliant futuregsc has a brilliant futuregsc has a brilliant futuregsc has a brilliant futuregsc has a brilliant futuregsc has a brilliant futuregsc has a brilliant futuregsc has a brilliant futuregsc has a brilliant futuregsc has a brilliant futuregsc has a brilliant future
Totally sick!!!
Old Sep 2, 2005 | 06:31 AM
Zlaatan's Avatar
Zlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant futureZlaatan has a brilliant future
2.5sec to 100km/h!!!!!!!!!!!!!!!!!!!!!!
ho-ly sh**!!!!!!!!!!!!!
Old Sep 2, 2005 | 06:33 AM
buddyg's Avatar
Originally posted by vtgts300kw
2.5 seconds 0-100
That is KPH (kilometers) which is about 62 mph still incredible!
Old Sep 2, 2005 | 06:38 AM
buddyg's Avatar
Re: AMS drives Bugatti Veyron - 402km/h 250 mph!
For the metric challenged 402 kph is 249.9 mph
100 kph is 62mph
200 kph is 124mph
25 meters is 82 feet
1950 kg is 4299 lbs!
Old Sep 2, 2005 | 06:58 AM
topspn's Avatar
topspn is infamous around these parts
Holy Cow!!!!
The bar has been raised I would say.
Old Sep 2, 2005 | 07:26 AM
buddyg's Avatar
I would rather have a Carrera GT and save $600,000. Put that bloated pig on the track and the GT would eat it for lunch. I mean 4299 lbs! Come on!
Old Sep 2, 2005 | 09:26 AM
HotRodGuy's Avatar
hence why it's not a track car Buddy
they aren't even competition for each other. This is a pure GT-Supercar. A guy isn't gonna cross shop the two.
Old Sep 2, 2005 | 09:27 AM
HotRodGuy's Avatar
almost all testing is done w/ the A/C off
Old Sep 2, 2005 | 09:37 AM
Terry56's Avatar
Porsche Enthusiast
Terry56 is infamous around these parts
It could go 600Km/h and I would still not like this car.
Old Sep 2, 2005 | 09:38 AM
Ryan in SD's Avatar
Ryan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to allRyan in SD is a name known to all
Originally posted by topspn
Holy Cow!!!!
...not really, this is more like a train...good for one direction at a time. Spectacular numbers none the less but I would also prefer a CGT.
Old Sep 2, 2005 | 10:01 AM
Ferrarislave's Avatar
Ferrarislave is infamous around these parts
I would take this car over the CGT any day, not only from a performance stand point, but for looks, exclusivity, and everything. The car looks specacular in black/blue with light intertior. I think there are already a few people in Bahrain who own these monsters.
