The GT3 gets dyno'ed after mods
Old Dec 12, 2007 | 09:21 PM
GT3Ranger's Avatar
GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !
First allow me to apologize, I could not get color when scanning the dyno graphs.
The two lower curves are hp and the two upper curves are torque. The lower curve of each pair is are the stock results and the upper curve of each pair are the results w/ FVD headers.
Stock = 363.3 rwhp //// Mod. FVD = 383.5 rwhp
http://picasaweb.google.com/whitneyd.../DynoResults03
View it in the slideshow, it projects larger.
Between 3300 to 5400 rpm is the real substance of the headers. There are hp gains of 25 t0 30 rwhp and 35 to 40 ft/lbs of torque.
Peak was a 20 rwhp and 10ft/lbs torque.
Several runs were done but with the increasing engine temp the results were becoming affected. It's hot down here.
Now to the Dymags, a topic that's awaited. Well let me tell you the results were a disappointment. The Dymag rep from California was there at Champion when we dyno'ed. We dyno'ed with the Dymags on and the results were as shown. Then we took off the Dymags and put back the HRE 890R's that were on previously and the dyno results were the same. No measureably significant hp difference. Many runs were done but no need to show redundant results.
These headers/exhaust system sounds great and look well developed.
The total weight savings is 39 lbs. exactly. Removal of the side mufflers equals 42 lbs savings but you must take into account the difference in the weight of the stock manifolds vs. FVD headers.
A system saying they save 60 lbs. I do not believe it.
The rear center section is NOT a muffler as often called, rather it is a resonator.
http://picasaweb.google.com/whitneyd...63/DymagWheels
http://multimedia.fvd-web.com/FVD111...11199750RS.wmv
Gentlemen I love this exhaust, it works, sounds great and the price is better than ALL competitors. Right now the FVD race exhaust is $4,000.
The Supersprint header and exhaust system looks good but results are still unknown. Long pipes are not necessary good for making power. I guarantee you this will cost 8 - 10K. Lets see but my SS headers for the M5 without Cats was 7K.
The QuickSilver header system looks good but there is little info out.
I know of a forum member who installed this system and got good dyno results. I do not know the price of the QuickSilver headers.
Cheers gentlemen,
GT3Ranger...Juan
The Supersprint headers system looks good
Old Dec 12, 2007 | 09:26 PM
silver_6r's Avatar
silver_6r is infamous around these parts
nice...sounds great too!!
good info...
Old Dec 12, 2007 | 11:09 PM
LUISGT3's Avatar
Very nice gains Juan.
Old Dec 12, 2007 | 11:17 PM
GalaxyGrey06's Avatar
GalaxyGrey06 is infamous around these parts
Is that what GT3s are making at the wheels? seems a little low?
Old Dec 13, 2007 | 04:20 AM
GT3Ranger's Avatar
GalaxyGrey06, the GT3 is 415 bhp from factory. What else are you expecting. There can be those out there who can fudge with the dyno.
You can really manipulate dyno figures. These numbers I'm showing are rock solid sound and real.
Let me know what you expected or have heard.
Cheers,
GT3Ranger...Juan
Old Dec 13, 2007 | 05:34 AM
Ritesh's Avatar
Ritesh is infamous around these parts
Congrats Juan - 20 HP gain and 25 - 30 in the mid range is impressive.
Btw, what dyno machine is that? Do you know the ambient temp and humidity?
Congrats again - great job on your cars!!
Old Dec 13, 2007 | 06:01 AM
GT3Ranger's Avatar
Ritesh : A dynojet was used. The ambient temp was 84 degrees and 78% humidity.
Old Dec 13, 2007 | 06:04 AM
ErikG's Avatar
ErikG is infamous around these parts
Juan,
Looks good, I thought that you also had FVD center mufflers ?. Also, I'm not that surprised that the light wheels do no show up on the dyno, the HP stays the same BUT (BIG BUT) I am sure that the acceleration of the car improved. This is the same as when people put in a LWFW. It does not show on the dyno, but everybody that does it feels the difference when driving. I think that even Porsche official #'s show at tenth of second better 0-60 time for the RS then the "regular" GT3, which can only be contributed to the light flywheel.
Sent you a pm
Old Dec 13, 2007 | 07:38 AM
GTS-R's Avatar
GTS-R is infamous around these parts
Originally Posted by ErikG
Juan,
Sent you a pm
I agree. I believe that changing the wheels should not actually affect power at all. Reason being that if you have a heavy or light wheel, the lighter wheel of course will have an easier time rotating initially. Therefore, a lighter wheel will show acceleration improvements. However, a heavier wheel, while taking longer to accelerate due to more energy/power required to move it will eventually rotate at the same speed as the lighter wheel as inertia/momentum will have built up. Therefore, measured power should be the same for both. However, the a car with a lighter wheel setup will 'feel' stronger and perform better as it can move rotate the wheels more freely so it will accelerate faster. Top speed which is a better indicator of HP should not change. However, the lighter wheel set up will reach the top speed sooner than the heavier wheel set up.
If my thoughts are correct, I wouldn't be disappointed with the dymags. I think you will find your acceleration will be better with them vs the HREs or stock wheels. Power should be unchanged.
Old Dec 13, 2007 | 08:14 AM
997gt3north's Avatar
997gt3north is just really nice997gt3north is just really nice997gt3north is just really nice997gt3north is just really nice997gt3north is just really nice
Juan,
What octane was used when dynoing the car?
Paul
Old Dec 13, 2007 | 08:38 AM
GT3Ranger's Avatar
Hey 997gt3north, Paul, I knew you'd be responding after our discussions.
Anyway the car was dyno'ed with what it only has ever run, pump gas 93 octane. The car does have the single mass flywheel from the RS but as was stated this doesn't reflect on the dyno.
In response to ErikG the most noticeable effect from the Dymags has been in braking. It feels like it takes much less effort to slow down or stop. Acceleration is hard to tell, with the headers providing the improvement in performance. The handling change with the Dymags is also tough to tell also having the cup suspension parts put in. The car is a brick but so sharp.
Good luck and consider it Paul,
Juan
Old Dec 13, 2007 | 08:47 AM
LUISGT3's Avatar
Juan,
What did the car weigh in at?
Old Dec 13, 2007 | 08:54 AM
scv8's Avatar
scv8 is infamous around these parts
Very nice gains.
I'm sorry if I overlooked it, but what is the weight difference between the Dymag and HRE, per wheel? Was the tire diameter the same?
Old Dec 13, 2007 | 10:46 AM
MeanMachine's Avatar
Great gains Juan, thanks for posting
Old Dec 13, 2007 | 11:34 AM
TYE's Avatar
TYE
TYE is infamous around these parts
Juan
So if Im looking at this right, you are running the FVD headers and 200 cell cats, and the stock rear resonator? Any plans to try out a different resonator?
