HELP: GT3 Suspention question
Old Feb 3, 2008 | 10:49 PM
GT3 Chuck's Avatar
Administrator
good one TK....you hooked your limit...nice lookin 3 and have a great 08
Old Feb 4, 2008 | 03:54 PM
Mvez's Avatar
Mvez has a spectacular aura aboutMvez has a spectacular aura aboutMvez has a spectacular aura about
Originally Posted by TK6
I'm not very impressed with the handling of my GT3, any suggestions on what kind a suspention I can put it to make it better ???
Now there's a comment you don't see everyday. I wish I had your problem right now......have a great '08 TK.
Old Feb 5, 2008 | 08:03 AM
AzGT3's Avatar
AzGT3 is infamous around these parts
I had Robert at Redline Motorsports in Phoenix do his version of the "Track" setup in our owners manual and corner balance my car. He said "you will not believe the change" and I can't!!! I have to relearn our local tracks. Understeer....GONE. Turnin.....all you have to do is think turn. "Darty" under hard braking......GONE. This on a car a dealer had aligned twice. Now I understand why even people from Calif. bring cars to him. The car is still great on freeways and around town.
Old Feb 5, 2008 | 09:23 AM
997gt3north's Avatar
997gt3north is just really nice997gt3north is just really nice997gt3north is just really nice997gt3north is just really nice997gt3north is just really nice
Can you post your setup - front and rear camber and toe
Always interested in what others are trying
Paul
Old Feb 5, 2008 | 05:53 PM
jay_ftw's Avatar
jay_ftw is infamous around these parts
Originally Posted by OldGuy
In one of my research visits to race teams, a crew chief told me when I asked him if
motons were needed for the GT3, that the 997 GT3 suspension does not need replacement,unless you are Micheal Schumacher or going wheel to wheel. It just has to be aligned properly. He looked at me paused and said "Porsche really got it right with this one." Take thats for what its worth. One mans opinion.
What if you're Tony Kannan?
Old Feb 5, 2008 | 06:43 PM
TK6's Avatar
TK6
TK6 is infamous around these parts
Good Answer......
One thing I learn in my race carrier : YOUR SET UP CAN ALWAYS BE BETTER AND THERE IS ALWAYS SOMEBODY BETTER THEN YOU.........
With that let's look for a better set up fpr a GT3...
Old Feb 5, 2008 | 06:45 PM
TK6's Avatar
TK6
Originally Posted by c2mojo
please tell us what its not doing for you? What do you want from the car, better turn-in, high speed stability etc
Understear like crazy..and it's not stable enough .....does not turn at all...
Old Feb 5, 2008 | 06:54 PM
jenk12m's Avatar
jenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant futurejenk12m has a brilliant future
how long do your tires last with the ''TRACK'' setup you have
Old Feb 6, 2008 | 01:17 AM
Juha's Avatar
Juha is infamous around these parts
Tony, I don't know jack about 997 GT3's but I do know that my 996 GT3 had the very same symptoms. They were easily fixed:
1. I rotated the front struts and dialed the suspension down to Kusmaul specs - BIG DIFFERENCE!
2. I learned how to drive the 911 the correct way ( http://www.zh.com/images/vettranio.pdf )
I don't think #2 pertains to you but I know I couldn't get the car to turn either. That was before I was thought how to rotate the heavy *** with brakes and gas. The car just won't turn without doing this...
Hahah! I just realized I'm telling Tony Kanaan how to drive a car... What's next? I'm going to teach Bill Gates how to make a little extra dough....
Old Feb 6, 2008 | 01:50 AM
datax's Avatar
datax has much to be proud ofdatax has much to be proud ofdatax has much to be proud ofdatax has much to be proud ofdatax has much to be proud ofdatax has much to be proud ofdatax has much to be proud ofdatax has much to be proud ofdatax has much to be proud ofdatax has much to be proud of
I assume tire pressure and alignment is correct because even from factory some cars came with off alignments. Quite surprised to hear that it's not stable enough because 7GT3s are suppose to feel a lot more stable and planted than 6GT3. For me, when my car wasn't turning in right (and understeers too), I soften up the front sways and asked the mechanic to toe-out a bit on the fronts. Also, as much negative camber as stock can take without rotating the struts like in Kusmaul setting, which is very aggresive. There are still minor understeer but it is much improved and street driving is also retained. Suspension kits like Ohlins, Motons and JRZ are pretty good and can turn the car's feel night and day as far as I've read in books/reviews. Search on Rennlist for a lot more info. There are a lot more people over there who push their cars.
Old Feb 6, 2008 | 02:42 AM
24lemans's Avatar
24lemans is infamous around these parts
Datax, Can you give me your alignment specs? I'm looking for something that isn't as agressive as the Kussmaul settings. Thnx.
Old Feb 6, 2008 | 03:11 AM
mishref's Avatar
mishref is infamous around these parts
Your car looks just like the one we got here
New tires (Hoosiers/Toyo) and track alignment will coarse more from the handling.
Old Feb 6, 2008 | 04:46 AM
YSS's Avatar
YSS
YSS is infamous around these parts
alignment
great thread guys
i have been having understeer issues on the 7GT3
so far i have tried 3 tires.
Toyo R888
Nitto NT01
Michelin PSC OEM N spec
the toyos have been the fastest although he Nitto's "look" the most aggressive and feel the softest.
Both faster than the michelin.
In terms of alignment,the best so far has been -3.25 degrees on the front and 2mm total toe out and -2.25 degrees on the rear with 2mm total toe in.
i have tried as much as 4mm toe out in the front - no good
i have tried as much as -3.75 degrees neg camber in the front but it was not materially different than -3.25; in fact my fastest laps have been with the negative 3.25 degree front setup.
about to put on a set of hoosiers to see the difference and lower he car 15mm allround maintaining pitch.
i have adjusted sway bars a few times and the softer setting seems to work better in the front. going hard in the front has resulted in lifting the front wheel mid corner occasionally. the rear doesnt seem to make a huge difference given so much grip.
one thing i did notice is Incredible high speed stability when i put the front toe out to 4mm (2mm each side).
keep the feedback coming
yss
Old Feb 6, 2008 | 06:00 AM
GT3Ranger's Avatar
GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !GT3Ranger Is a GOD !
So TK I heard Motons it is! Was hanging out with Ben yesterday and it came up in conversation.
Man I'm telling you, we have to take my GT3 wringe it out. You are going to like it.
Good luck and see you soon,
Juan
Sep 10, 2015 03:20 PM
Sales@RSW
Sep 3, 2015 09:34 AM
Money2536
Sep 1, 2015 04:56 AM
mlife2878
Aug 26, 2015 07:02 PM
pwdrhound
Aug 20, 2015 05:54 AM
