opinions on dassport bar
Old Apr 1, 2008 | 05:23 AM
  #31
YSS's Avatar
YSS
YSS is infamous around these parts
Originally Posted by jonathan@millaracing
Joe
many thanks for your orders once again.
The bar looks great painted white and your car is a stunner!!!!!
jonothan
the rear mounts to the suspension
what does the front of the bar mount to - are you needing to weld some plates in?
Is the DASSPORT bar rated as a safety bar or is it being put in to just strap a harness to?
My car is a touring versipon and does NOT have the mounting points for bar in the floor.
thanks
yss
Old Apr 1, 2008 | 07:06 PM
  #32
930man's Avatar
930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future
tech equp. is not a rs bar
Old Apr 1, 2008 | 11:49 PM
  #33
///M Kevin's Avatar
///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold
Post some pictures of the cage.
Old Apr 2, 2008 | 12:58 AM
  #34
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
Here is my OEM RS,I made 2 metal plates with 3 holes to secure the roll bar to the floor and it works fine.
Old Apr 2, 2008 | 08:14 PM
  #35
speedoflight's Avatar
speedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud of
Originally Posted by YSS
jonothan
thanks
yss
there's no welding involved. everything is bolt on. the front bolts to the seat belt mount. i may have a picture of it somewhere. if not i'll take one.
Old Apr 2, 2008 | 08:16 PM
  #36
Originally Posted by ThisFlyGuy
wow, it looks great Joe!!!!! car is looking good!
thanks mike. how you like your new m5?
Old Apr 2, 2008 | 08:55 PM
  #37
BOYRACER's Avatar
BOYRACER is a splendid one to beholdBOYRACER is a splendid one to beholdBOYRACER is a splendid one to beholdBOYRACER is a splendid one to beholdBOYRACER is a splendid one to beholdBOYRACER is a splendid one to beholdBOYRACER is a splendid one to beholdBOYRACER is a splendid one to behold
I have one in my 04 GT3 and the fitment and quality is top notch
Old Apr 2, 2008 | 09:20 PM
  #38
mooty's Avatar
mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !
the triangulation of the RS bar is better than DAS. the rear "X" of DAS is not a the node, thus causing stress riser at the point where the "X" meets the main hoop.
however, those in norCal should really look at tcdesignfab's bar. it's better made, tighter fitting then any of the above.
Old Apr 2, 2008 | 09:30 PM
  #39
CarNerd's Avatar
CarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant futureCarNerd has a brilliant future
John, what does the cost on their bar run with install?
Old Apr 2, 2008 | 11:49 PM
  #40
Daytonaviolet's Avatar
Daytonaviolet is infamous around these parts
you have any pics of the tcdesignfab's bar?
Old Apr 4, 2008 | 10:11 AM
  #41
cwjr's Avatar
cwjr is infamous around these parts
The recent Excellence article on the Werks turbo package installed by Champion really panned the roll bar....said it was continually squeaking and quite annoying. Any feedback on the noise factor of the rollbars mentioned in this thread? I am looking for a bar to install on my soon to be delivered GT-2, and want to avoid a squeaker.
Old Apr 4, 2008 | 11:39 AM
  #42
Andrew D.'s Avatar
Andrew D. is infamous around these parts
No squeaks with my DAS bar. The only noise I have is an occasional rattle from the harness hardware where the harnesses connect to the floor mounts.
Old Apr 4, 2008 | 11:43 AM
  #43
jonathan@millaracing's Avatar
jonathan@millaracing is infamous around these parts
no squeaking on the dassport bar
GT2 bars available next week
https://www.6speedonline.com/forums/...d.php?t=125114
Old Apr 4, 2008 | 11:58 AM
  #44
i've only had mines (das) on for about a week. no squeak.
Old Apr 8, 2008 | 09:55 AM
  #45
endlesswinterco's Avatar
endlesswinterco is infamous around these parts
I installed this Dassport bar for a customer awhile back. he loves it, no complants.
