KW Hydraulic Lift System
Old Oct 27, 2008 | 02:27 PM
  #61
AutoTalent's Avatar
AutoTalent is just really niceAutoTalent is just really niceAutoTalent is just really niceAutoTalent is just really niceAutoTalent is just really nice
Originally Posted by juankimalo
So, you can go for it in a 996 if you have KW coilovers installed... I can see that the problem comes from the CAN.
Would it be match in a 996 C2 with KW coilovers too?
With KW Coilovers, there is a system for the 996 C2.
Old Jan 6, 2009 | 09:12 PM
  #62
GTS-R's Avatar
GTS-R is infamous around these parts
Anymore feedback on this system for those who have installed it?
Old Jan 6, 2009 | 09:25 PM
  #63
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
I am installing one now in a TT and the quality is very nice no problems yet,tomorrow we will purge the system and start setting the car etc.
Looks nice I hope it is not only for bling but is works great in the track too.
Old Jan 6, 2009 | 09:31 PM
  #64
deputydog95's Avatar
deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !deputydog95 Is a GOD !
I run my car fairly low and have few issues. Worst case scenario is that I scrape the black plastic replaceable lip spoiler. I've scraped it probably hundreds of times at this point and it still doesn't look that bad. What are you guys doing to necessitate a lift? A very expensive one at that
Old Jan 6, 2009 | 09:32 PM
  #65
What purpose would it serve at the track?
Old Jan 6, 2009 | 09:53 PM
  #66
luiscarlos's Avatar
At the track the only advantage is that the car can be very low and then in the street it can be raised.
In the past I wanted my car to be lower for the track and I cant because it was a PITA in the street.
Old Jan 6, 2009 | 09:59 PM
  #67
Will you ride around with it jacked up in the street, or only when you come across an obstacle?
Old Jan 6, 2009 | 10:05 PM
  #68
luiscarlos's Avatar
I will use the low setting when the road is good and no speed bumps,when the road sucks and speed bumps I will have to use the 4x4 look.
I think this system will give a 45mm range.
Old Jan 7, 2009 | 05:42 AM
  #69
If you set your alignment for the low setting, will it be thrown off considerably if you ride around at the higher settings on the poorer roads?
Old Jan 7, 2009 | 05:57 AM
  #70
03-turbo911's Avatar
Senior Member
Excellent quistion that's yet to be answered. It will change the settings is my guess but will it revert to the same values when lowered? Camber, castor and toe-in/toe-out.
Old Jan 7, 2009 | 06:00 AM
  #71
GTS-R's Avatar
How difficult is the install? How much should I expect to pay from a reputable shop?
Old Jan 7, 2009 | 06:01 AM
  #72
I agree. It will change when going up for sure. I am just wondering if repeated "up and downs" will cause it to change quicker than it normally would from regular driving...
Old Jan 7, 2009 | 11:42 AM
  #73
luiscarlos's Avatar
Good point I will have to mediate the setting and measure in low and high ride height,camber will be affected and toe too bit the height ride height will be for low speed.
Old Jan 9, 2009 | 08:43 PM
  #74
luiscarlos's Avatar
Tomorrow I will start setting the susp geometry with the KW HLS,anyone knows or can recommend compression and rebound for 997 TT?
Old Jan 10, 2009 | 05:36 AM
  #75
Senior Member
I had KW coilovers before and if I remember right, they come pre-set from the factory. You need to contact the dealer that sold these to you and get KW's recommended settings to use as a guide.
