ceramic break pads
Old Jun 25, 2008 | 02:36 PM
wct8920's Avatar
wct8920 is infamous around these parts
ceramic brake pads
Are there any special pads that have to be put on them? Any recomendations for a car that will be driven on the street occasionally but mainly on the track?
Thanks guys.
Pics of the GT2 coming soon!
Old Jun 25, 2008 | 09:49 PM
wct8920's Avatar
anyone?
Old Jun 25, 2008 | 11:22 PM
luiscarlos's Avatar
luiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud ofluiscarlos has much to be proud of
Oem.........
Old Jun 26, 2008 | 05:54 AM
sheim911rs's Avatar
sheim911rs has a spectacular aura aboutsheim911rs has a spectacular aura aboutsheim911rs has a spectacular aura about
I use the factory pads at Road America which is a high speed track. No problems. I inquired with a local race gear supplier about pagids and he told me to stay with the stock pads. Send pictures of your track days!
Old Jun 26, 2008 | 02:31 PM
SuncoastSteve's Avatar
SuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to beholdSuncoastSteve is a splendid one to behold
I believe if you use a non-OEM pad on your ceramic brakes, not only do you raise the risk of damaging your rotors, but you actually void the warranty on your brakes.
I also just spoke to one of our head techs, and he said that there are actually Porsche Motorsport pads that you should use for the track, as they are made for higher temps than the factory pads. Of course, don't use these pads on the street, you probably won't get them hot enough to be effective.
Either way, stick with Porsche parts on these, or swap over to iron rotors and use whatever aftermarket pads you want!
Old Jun 27, 2008 | 03:14 PM
On Pole's Avatar
On Pole is a jewel in the roughOn Pole is a jewel in the roughOn Pole is a jewel in the rough
I use the green motorsport pads on the street and track.
Old Aug 21, 2008 | 12:27 PM
rickg87's Avatar
rickg87 is infamous around these parts
Does anyone know how Much to replace the OEM ceramic pads?
I'm just about there.
Old Aug 21, 2008 | 05:51 PM
///M Kevin's Avatar
///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold///M Kevin is a splendid one to behold
Wow, what's the mileage on your car and do you track it? They're supposed to last long.
Old Aug 22, 2008 | 06:23 AM
rickg87's Avatar
I just replaced the tires. So looking at the pads, the fronts still have more then half left, but the rears are less then half. The rotors look ok to my novice eye.
I have 4400 miles. Around 8 track days.
I thought they would last longer. It's interesting that the rears are wearing faster then the front. But I have heard that happens on these cars.
PV=nRT.
Sep 9, 2022 06:06 PM
XLR82XS
Oct 5, 2015 07:02 AM
Goonie
Sep 12, 2015 02:10 AM
