997 GT3 race headers/ exhaust suggestions?
I've found lots of exhaust threads here, but none that are race specific...
I’m looking for a race exhaust for my ’06 997 GT3 cup motor. I need both the headers and mufflers, and I don’t need to worry about cats or have a strict sound limit. I’d been planning to use GT3 RSR headers that I've got and make a muffler, but I've been told that kills too much low end torque for what I'm doing.
So has anyone seen good headers or full race exhaust systems for GT3s/ cups? Preferably light weight, and not 8k? I know hergesheimer made a nice piece for the 996 cup, but I don't think they did 7s (and it's not cheap):
http://www.hergesheimer.com/hergeshe...e_exhaust.html
-Pete
-Pete
Thanks for that idea Alex.
Well the headers look interesting. I could almost come straight off of those with a couple straight Coast mufflers, dumping the cats, etc. As you say I'd need to check clearance.
Does he have an ad posted, or do you have any other details?
-Pete
-Pete
-Pete
-Pete
Or just plug off the small pipe?
-Pete
-Pete
You need the Porsche Motorsports World Challenge Sprint exhaust. Loren at 911 Design has one available. loren@nine11design.com Tell him Garrett told you about it.
Update- I test fit the cargraphics system today. The headers are very nice, well done pieces, but unfortunately they don't fit in my application. I've got a narrow enough track and the motor shifted forwards far enough that they hit the rear wheels by a couple of inches. Shame, because otherwise they look very good (2" OD x 19" primaries).
I also chased down the PMS World Challenge system, but I determined that it would hurt torque as it uses even larger primaries than what I already have (I've got the GT3 RS racing headers- 2.15" x 19" primaries).
Any other suggestions for headers or systems to look at?
Gentleman
The standard production engine in the GT3 does not have enough compression to take advantage of a true racing exhaust like the World Challenge system.
Our racing engines (WC)including the stock cup have more compression, different cam profiles , different electronics etc and are designed to take advantage of a free flowing exhaust system.
If you are looking for me speed around the track or reduced lap times, your money is much better spent on suspension upgrades..........
Gentleman
GMG makes and sells a number of exhausts for the gt3s, cups... Any suggestions for what to use, or what size to use? I believe most "street" GT3 headers use 2" primaries- think 2.15" is too large? I can of course run the WC rather than cup engine map, which should help a bit...
To be clear I have no headers or exhaust at all right now, so I need to find something...
Yes, that sounds correct to me. I believe the WC uses both the RSR cam and the stepped-tube RSR headers, which probably work well as a matched set at high rpm. With the milder cup cam and my desire for more torque those headers sound too large.
Pete to be honest I think the 997GT3 Cup is the best system for a production GT3/RS if you want to make some power. The systems uses a high flow sport catalyst, eliminates the primary mufflers and uses a revised rear muffler.
Since the headers and cats are close to what is stock on the car, less the bypass flaps it probably makes for the best upgrade for a street car that sees track use.
The DME used in the cup and world challenge cars is a bosch motorsport unit and does not adapt to a street car with vario cam and E- Gas.
The AWE system is good alternative as well. Although I have not installed or tested one myself.
I think your best bet is to run the GIAC software re-flash on your car.
Fabryce, is your recommendation the GMG GT3 sport exhaust?
Have you checked out the Oakley Designs GT3 system? Curious to know what you think.
http://www.oakleydesign.eu/titanium-...system-997-gt3
Does that change your recommendation?
Ahhhhhhhhh got it!
Call me on Monday or email at the shop fabryce@gmgracing.com. I have something you might be interested in
which includes a tune for your motorsport DME.
Looks pretty cool, we are going to install one for a customer and dyno the car before and after to see what kind of power it makes. I have not had an oppurtunity to see the actual system in real life.
Will take some pictures and post the results once we are finished with the project.
Form the pictures it looks like a early cup style muffler with later style headers. Similar to what quicksilver is making.
Cool, Im curious to see the results. I plan on using these systems soon.
Any dyno tests for the GMG GT3 system?
