Navigation Retrofit
Old Sep 11, 2008 | 02:27 PM
YseanY's Avatar
YseanY is infamous around these parts
Navigation Retrofit
I just bought a used PCM 2.1 and Navigation for my car. The PCM install within 5 mins and everything is working correctly. However, I'm having trouble with the navigation unit. I believe the 997 S and GT3 (mine) uses the vertical mount navigation and my part numbers below should be for this. I cannot find a space to fit the unit! Am I suppose to remove the plastic cover in the center of the trunk to place the DVD drive?
Navigation drive 997.642.159.01
Bracket 997.642.231.00
I think i'm missing some hardware and maybe a longer MOST cable to get to the below. Anyone know the part numbers i need?
Some help would be great! Thanks!
Old Sep 11, 2008 | 02:53 PM
OldGuy's Avatar
OldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond reputeOldGuy has a reputation beyond repute
Those are some good questions. I dont know of anyone doing a retrofit, much less a retrofit by themselves.
Good Luck
Old Sep 11, 2008 | 03:28 PM
Daytonaviolet's Avatar
Daytonaviolet is infamous around these parts
i've done it you'll need a new bracket and housing cover like this. i have more pictures and part #'s at home. btw, do you have Bose or None Bose PCM?
Old Sep 11, 2008 | 05:19 PM
YseanY's Avatar
non bose pcm... the pcm works flawlessly, except for the link with chrono
can you post the part numbers when you're home? also, do i need another, longer MOST cable? i believe i have 997.622.707.00
Old Sep 11, 2008 | 05:54 PM
okay so if you only have the navigation module (dvd player), then all you need is just one MOST end. do you have one already?
Old Sep 11, 2008 | 06:05 PM
YseanY's Avatar
i have the PCM 2.1 installed already and i have the below parts left to install
MOST cable 997.622.707.00
DVD power cable (don't remember part number)
GPS antenna and cable (don't remember part number)
Old Sep 11, 2008 | 06:13 PM
Jgalt's Avatar
Jgalt is infamous around these partsJgalt is infamous around these parts
996 or 997
Which model GT3 do you have?
Old Sep 11, 2008 | 07:09 PM
looks like a 7gt3
Old Sep 11, 2008 | 08:05 PM
YseanY's Avatar
looks like a 7gt3
yep, 997 gt3
Old Sep 13, 2008 | 08:58 AM
Jgalt's Avatar
Finish the story
Don't forget to let us know how everything works out. I am thinking of doing the same thing myself.
Old Sep 13, 2008 | 06:23 PM
sean, do you have bose pcm? if not, do you have any idea how to install mobridge like products?
Old Sep 14, 2008 | 11:47 AM
YseanY's Avatar
once finished i'll update everyone! just need a few extra part numbers to finish up!
Old Sep 14, 2008 | 11:48 AM
YseanY's Avatar
nope, no bose pcm, no cd changer. as for mobridge, don't have the slightest clue yet. but i think it should be farily easy shouldn't it?
btw fern, you get a chance to look up the part numbers for me? thanks!
Old Sep 14, 2008 | 05:54 PM
sorry i dont have the part numbers. i just went to dealer and asked for the plastic bracket, housing and new carpet for a 4S with no bose. they should have it in there pet.
Old Sep 14, 2008 | 06:06 PM
YseanY's Avatar
got it... btw, do you have the part number for the MOST cable? i don't think mine is correct (997.622.707.00 for non-bose, no CD) as it looks to short to reach down there.
any chance you have pics of your DIY for the navi unit install?
