intermediate shaft
Old Oct 24, 2008 | 02:02 PM
Wayne K's Avatar
Wayne K is infamous around these parts
intermediate shaft
There has been much discussion lately on PPBB regarding IMS failure resulting in a expired engine. I know our GT3 motors are based on earlier 911 engines (prior to 996 models except for turbos) but I don't recall if the GT3 engine has a intermediate shaft that can fail as with the 996 and 986 motors.
Old Oct 25, 2008 | 04:16 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
GT3 engine based on GT1 engine as well. Similar in basic (emphasis on basic) construction to the 996TT engine. GT3 engine has no intermediate shaft.
Old Oct 26, 2008 | 05:00 PM
Porsche917's Avatar
Porsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to beholdPorsche917 is a splendid one to behold
The gt3 style engine does have an intermediate just not like the 996/997.1 it doesnt go all the way through the block.they are not prone to failing in the same way..... the new motor in the 997.2 truly doesnt have an intermediate shaft.... the two chains are driven off the crank only and a seperate chain drives the oil pump, where as before the oil pump was on the end of the intermediate shaft on the belt drive side.
Old Oct 26, 2008 | 05:04 PM
JP-S-St.Louis's Avatar
Just a boxster?
JP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond reputeJP-S-St.Louis has a reputation beyond repute
GT3/TT/GT2 all have the GT1 style motor thats has been around for years and NO IMS issues.
Now the 996,986,997 and 987 are all M96 and M97 motors and are known to have issues with the IMS.
Contact Flat 6 Innovations as they have created a new style IMS for these motors.
Old Oct 26, 2008 | 05:05 PM
Correct on the fact that it does have one, just in no way similar to 996/7.1 shaft. Direct gear drive to oil pump in GT3.
Old Oct 27, 2008 | 09:35 AM
Wayne K's Avatar
Thanks for the education.
I'll sleep better now at least with regard to the GT3. The Boxster S still keeps me awake now and then.
Old Oct 28, 2008 | 08:20 AM
otisdog's Avatar
otisdog is a splendid one to beholdotisdog is a splendid one to beholdotisdog is a splendid one to beholdotisdog is a splendid one to beholdotisdog is a splendid one to beholdotisdog is a splendid one to beholdotisdog is a splendid one to behold
So the RMS and IMS issues are unrelated?
Old Oct 28, 2008 | 01:30 PM
Wayne K's Avatar
Yes.
Old Oct 29, 2008 | 07:31 PM
Yes.
To some degree. A portion of "RMS" leaks can also be attributed to the seal that goes around the IMS directly below the RMS. I have even seen some of the leaks in this area require splitting of the engine case to be completely resealed. There have been a couple of updates in what they call the "flange" of the IMS. I have also seen some transmission pulled out only to find the RMS dry but the area around the IMS flange wet with oil. Most places I know of replace both the IMS flange and the RMS if there is an issue, along with even updated engine case bolts in the problem area that have sealant on them now. There are also 2 styles of flanges that CANNOT be mixed up.
Steve Jarvis
Apr 1, 2023 06:49 PM
nyjetfan
Oct 17, 2015 01:32 PM
panas001
Sep 27, 2015 02:51 PM
